Hi guys, im a newbie here. Greetings
I have been using x7 for about a week and i found it sounds amazing, and which is better than my previous ak100ii. More impact in the low bottom and bigger soundstage, even the differences is subtle but noticable enough. The sq is amazing, but the software needs improvement here and there. A few suggestion to improve from me to
FiiO JamesFiiO
1. Please add the unsync lyric, i have none synced lyrics so its pretty useless for me. Maybe you can add it simply after the sync lyric screen, tap once and it will show the unsync lyric. Or you can show the available one
2. Please make it supports m3u playlist, its kinda hassle when you have a playlist tab, but you have to open the folder browser and go to your imported playlist file, then open it. Cant you just integrate it into one tab?? Just like ak100ii
3. Please make it remember the last playlist so it can continue where it left last time after reboot. Im currently at fw 2.0 and everytime i reboot, my last played item is gone. Its bothering since i usually make a big number in playlist, and i wanna continue where i left off
4. Please add album artwork in lockscreen while playing the tracks, most player support it and you can add this feature
5. And maybe android 5, since it wont have limitation in SRC so it will play any music in its native sample rate. CMIIW
Maybe that's all. Until you guys add those maybe i can stick with jetaudio
And maybe anybody knows, can jetaudio play 24 bit natively?? While its playing 24 bit tracks i saw it only output to 16bit 44.1KHz
Thanks
