jfs95
- Feb 6, 2016
Does anyone know where the AM3 Balanced Unit will sit, power-output-wise? I'm guessing it'll sit somewhere between the medium and high power units?
for some reason my X7 tries to play the first line of my m3u8 file, which is :
#EXTINF:622,A Winged Victory For The Sullen - Atomos I
this is not the file. the file is one line lower:
A Winged Victory For The Sullen/2014 - Atomos/A Winged Victory For The Sullen - 2014 - Atomos - 101 - Atomos I.flac
the entire structure of my playlist is as such:
#EXTINF:348,Muse - Aftermath
Muse/2015 - Drones/Muse - 2015 - Drones - 110 - Aftermath.flac
#EXTINF:607,Muse - The Globalist
Muse/2015 - Drones/Muse - 2015 - Drones - 111 - The Globalist.flac
#EXTINF:172,Muse - Drones
Muse/2015 - Drones/Muse - 2015 - Drones - 112 - Drones.flac
#EXTINF:301,Nirvana - Smells Like Teen Spirit
Nirvana/1991 - Nevermind/Nirvana - 1991 - Nevermind - 101 - Smells Like Teen Spirit.flac
#EXTINF:255,Nirvana - In Bloom
how do i stop this from happening? it only happens with the very first line of the file.
some technical data:
file saved using Kate for GNU/Linux, BOM (byte order mark) on, saved in UTF-8 encoding.
I've got a silly question.
On the default player app, while I'm playing through an album, how do I see a "now playing" type of list to show what tracks are coming up ahead on that album?
Going back to the Local Music browser view isn't practical because it just remembers where you were browsing rather than what list is currently playing.
on the player, swipe from left side of screen
Hi All
I've got a FiiO X5 2nd Gen and Fidue A83 IEM's. I'm thinking of getting a X7 with the AM1 module, as you won't be able to choose what module you get for a while yet. Nice move FiiO!
My question is, apart from Bluetooth and WI-FI, what sonic improvements could I look forward to? Or should I wait until I can purchase the X7 with my choice of amp module?
Regards
Darren
In order to properly use the AM5 do I need to upgrade to the newest firmware? If so, if I am not using equalization will I have any problems with the firmware? I have primarily been running my X7 in pure music mode and occasionally using the bluetooth connectivity.
I'm just trying to make sure I don't cause myself a problem by updating to the latest firmware to use the AM5.
Thanks
Mike
I disabled the swipe to skip track feature.
How?
Yes, the AM5 needs to work with the new firmware FW1.91. And if you don't use the equalizer and Blutooth at the same time, there shall be no extra problem with the update.
... but I had heard that you can't EQ a Bluetooth stream anyway.
...plus, if using the EQ and Bluetooth can cause issues for some X7 users, knowing whether or not to even bother with an EQ when using Bluetooth will save them some frustration.
Yes, EQ works with Bluetooth.
I have mentioned the problem here a few times. @FiiO has issued a couple of statements here--including a possible fix in the next update.
Oh, wait, now I get your last statement. Yes, EQ works with a Bluetooth stream.
