majo123
- Jan 1, 2016
I think you might have the wrong idea about this '11 pins' cable - a typical microUSB cable (the kind that does come with FiiO X7 and most Android smartphone) only has 5 pins, and that's all you need to connect X7 to your PC for files transfer or USB DAC function. You ONLY need a special 11 pins cable if you want to get the line-out from the microUSB port in X7. However, X7 already has a 3.5mm socket that you can get the line-out, so there is very little to no reason why you want a special 11 pins cable. Besides, I don't know anyone is making this kind of special 11 pin cable for FiiO yet.
In that case, keep the E12A.
thanks .....i had tried mine stacked with my E12a but honestly coming from my x5 + e12a i prefered x7 on its own with IEM module, just seemed a little more detailed , although all hearing is subjective ...thanks anyway.
