ph58
- Jan 2, 2014
Another question for the FW update , if i 'm not wrong , the File must be not unzip , just copy to the internal or the external Micro SD card , is it right ? Thank you .
Or you do an OTA update if you're on FW 1.3 or higher. IMO I think that's a lot easier.
What is a OTA update ? Thanks
Over the Air. Update wirelessly over internet in other words. When you enabled Wifi on your X7 it will automatically prompt you if you want to do an FW update if any are available. OTA feature is available since FW 1..3
Over several months I have suggested Dapper for Mac folks. There are several post where I offer tips on how I have configured iTunes & playlist. Most should be in the FiiO threads, just search. I use Dapper with FiiO X1, X5 and X 5ii and maintain several iPods all from iTunes/Dapper.
Most of my music is ALAC with a few AAC and mp3s. High res gets dragged over to a file just for them, not many but a few to experiment with.
Prior to a Dapper update along the way that added the cleaning of unwanted/needed files from the cards, I removed the synced cards front the FiiO and mounted them to the Mac and ejected with eject for windows, then back into the Fiio and run update scan and all was fine. Now Dapper seems to take care of this.
Jeremy Laurenson,
Thank you for a wonderful program and for being here.
r2
Well, no. Coaxial output bypasses the DAC and is a digital signal. So, if you want digital out you can use coaxial out, or USB out as per @ClieOS's post above.
Of course the shared line out / coaxial out jack needs to be set to coaxial. And no, you can't just use the 'amp' of the mojo. Digital input only with the Mojo (USB, coaxial, optical TOSlink).
James,
When will the medium amp module be available? Will it be bundled with the X7 or we have to buy the X7 with the iem and then the medium module?
Thanks in advance
we should ship some to our agents tomorrow. not so many cause we don't know how many people will need it. the first batch is 800pcs and the second batch is 2000 pcs after 2 months so I guess it must enough .
