FiiO X7 | DXD | DSD | 384K/64B | ESS9018+ Android | WiFi | Bluetooth | 4 AMP modules | Balanced Out |
Jan 29, 2016 at 7:12 PM Post #8,762 of 18,020
Is USB transport going to be included in the next firmware?
FiiO says USB DAC function will be functional in the next firmware. Is that what you mean?
Jan 29, 2016 at 9:28 PM Post #8,765 of 18,020
You should be able to right now. There is a setting in settings for coaux / line out. Port is on top of X7
But that means the signal has already passed through the X7 DAC so that would kind of defeat the purpose of using the Mojo. I'm guessing the poster wants to get digital out before it hits the X7 DAC? I could be wrong, maybe he/she just wants the amp of the Mojo?
Jan 29, 2016 at 9:43 PM Post #8,766 of 18,020
No I mean the ability to drive a USB DAC like mojo.
As I have posted quite some time ago, you can use Mojo with X7 as long as you use USB Audio Player Pro with USB Tweak 1 enable.
Jan 29, 2016 at 9:52 PM Post #8,767 of 18,020
this thing is quite thick! i wish this and the astell & kern jr would have a baby!
this ui mixed with at a&k jr form factor
Jan 30, 2016 at 1:32 AM Post #8,769 of 18,020
Originally Posted by RebeccaSugar /img/forum/go_quote.gif
Jan 30, 2016 at 2:12 AM Post #8,770 of 18,020
Well, no. Coaxial output bypasses the DAC and is a digital signal. So, if you want digital out you can use coaxial out, or USB out as per ClieOS's post above.
Of course the shared line out / coaxial out jack needs to be set to coaxial. And no, you can't just use the 'amp' of the mojo. Digital input only with the Mojo (USB, coaxial, optical TOSlink).
Jan 30, 2016 at 5:06 AM Post #8,771 of 18,020
hi there,
I am new in that forum.
Lots to explore.
Have now also a Fiio X7. Use it with headphones from Sony< MDR-Z7. To be honest, the sound is not that impressive with that headphones. not enough volume, not so clear, etc. I use a LG V10 with that headphones. Installed the new poweramp alpha apk. That sound is just amazing. Any idea why the sound is so different? Did I miss something in the settings?
will be nice to hear some opinions.
thx
Schuertzi
Jan 30, 2016 at 6:45 AM Post #8,772 of 18,020
hi there,
Lots to explore.
thx
Schuertzi
Did you check the gain options in the settings?
Jan 30, 2016 at 7:35 AM Post #8,773 of 18,020
Thx for the quick reply,
yes I saw the settings, but there is not much, just low and high. May be the headphones are the problem. may be 70 Ohm is too much?
Tried the EQ as well. it becomes a bit better, but the LG V10 phone is far ahead.
To wait for the additional modules?
Jan 30, 2016 at 9:30 AM Post #8,774 of 18,020
try set the gain to high first and them you may need some time to check out the difference between X7 and lg v10
Jan 30, 2016 at 9:33 AM Post #8,775 of 18,020
not, the 1.8 firmware will be released in the day after tomorrow. ( tomorrow is Sunday in China )
