szmer
- Sep 12, 2014
- The Size is not overy important as long as its not bigger than 13cm x7cm x 2 cm
-Screen Size i think 4" is more than enough, after all i dont want to browse internet with it. Smaller would be ok too.
- Battery life should be at least 8h
- The Amp section should be at least good as on the e12 but i dont know enuff about it to have an opinion.
- NO Bluetooth needed..i got Bluetooth on my smartphone APT-X aswell and since i think its gonna be industry standard for most smartphones when the x7 arrives. why waste the space.
- Also no wifi needed but appreciated. There is a gazillion of other devices to connect to your network player etc. Only put in if you have left over space and dont need to compromize on other stuff for that.
- depending on the size I'd like me a 6,3mm jack next to the 3,5mm and besides that the same in/out as on the kunlun
-would be cool if battery was replaceable, and the device can be opened, i don't mind undoing some screws.
-What would be super sweet from my point of view, and what i havent seen on any other device yet, was a remote, that would be either plugged in (2,5mm?) and have a, say 30 cm long cable so i could have the x7 in the pocket and could just clip the remote to the belt of the trouser or so. If bluettoth was to be included, I'd like a wireless remote.
Don't want to sound overly dramatic, but imagine how little additional work it is for fiio (ok lies
, and how much comfort it is, specially for disabled people, that are uncomfortable with pulling out a failry heavy and expancive device out of somewhere using their 3-fingered-one hand
-price could be up around whatever the newest iphone costs at that time, but since they tend to go crazy I'd say 700$
You could charge extra for the remote!
