updated on 7st, Nov, 2014
1, Dimension: 128*16*64mm
2, Screen: 3.97 inch full touch IPS
3, Battery life: > 8 hours
4, Battery: 3700mAh.
5, Hardware buttons: power, play/pause, previous/next, volume+/- and one secret bottom.
6, Input/Output interface:
Micro SD slot X 2
Micro USB X 1, ( As docking connector too cause we used 11 pins Micro USB )
3.5mm Line Out/ Coaxial output
Headphone out X 1, the output jack will change from 3.5mm output jack, 4 pin balanced output ( same as ALO/RSA ), depended on the headphone amp module .
7, Build in Memory: 16 or 32 GB depended on the cost when it is released .
8, Wifi/Bluetooth support.
9, DAC: ESS9018 X 1, ESS9018 already includes 8 channels DAC so it does not need 2 DAC chips.
10, OP and Buf for AMP, depended on headphone amp module.
11, Output power and power supply: depend on the amp module.
12, Soc: RK3188
13, Build in Memory: 32GB
14, RAM: 1GB
I have been in contact with consumers a lot ever since we stepped into the music player industry. The most impressive thing is that everyone got a dream player in mind, from function to OPAMP, DAC and display, etc. Meanwhile, we are also on the planning stage for some future high-end products, then why not we creating an ideal music player together, not only for FiiO, but for all the consumers.
No doubt this gonna be a very interesting thing, and we would try our best to seek all the possibilities to meet the demands from all of you. In case of any disagreements, we would start a vote to find out the best solution (PS. This activity would open to audiophiles all over the world, so we would coordinate the voting from users in China mainland as well).
Someone out there would doubt it to be unscientific or unserious, but HiFi is all about entertainment and to keep everyone happy, right? Rather than making profits, the main target of us in designing high-end players is to challenge ourselves to realize the dream of us and all the audiophiles.
Meanwhile, there would be some consumers claim that our X3 and X5 are not perfect enough, and will it be irresponsible to talking of dream device at this stage? Here I want to make a few explanations as follows:
1. Now we are only talk about this program in paper, our R&D staff will only get involved after the final design had been confirmed.
2. I’ve been in the process of recovering, so all the interaction would be in charge by me, which won’t affect the operation of the company. And actually, I am not responsible for any detailed daily work of our company, so please be rest assured.
updated on 3st, May, 2014
Here we have some decision about our new flagship portable DAP as below.
Model NO. X7
ETA: 2015
M.S.R.P: $699 in U.S
OS: Custom OS based on Android, can supports some third party APP from our website.
Weight: Less than 300g
Size: thickness will be almost the same as X5 , the other size is almost the same as 5 inch Android Phone.
Screen: 3.5 inch ~ 4.3 inch Full Touch Screen. To be decided.
Key layout: Full touch control+ Bottoms+ Volume Knobs
Output power: > 300mW/32 ohms, Power supply: +/- 6V ~ +/-11 V . To be Decided.
Playtime: 10 hours
Battery: Build in Battery.
Data transfer: USB 2.0 ( Micro USB), WiFi
Blue Tooth: YES , supports APTX
DAC chip: ESS9018 , not ESS9018M2K, The ES9018 includes 8 channels DAC which means it is equal to 4 X ESS9018M2K
Enclosure: Metal
Build in memory: To be decided.
Extra Memory: Micro SD slot X 2
Accessory : Leather Case X 1, Micro USB cable X 1,
One of the rending design picture of x7
Note this design had been denied cause I am not satisfy with it .
