FiiO X7 | DXD | DSD | 384K/64B | ESS9018+ Android | WiFi | Bluetooth | 4 AMP modules | Balanced Out |
Oct 27, 2019 at 4:14 PM Post #17,941 of 18,020
I am using 4 :) X7 I units at different working locations and on the way (and an X7 II at home). And I can tell you that it is worth having the X7 I s. Actually since I drive them with AM3 each, without direct comparision I could not tell a sound difference to X7 II. Bought them all in very good to mint conditions ... and pretty cheap. I am very happy with them and would not sell any of them. So I would recommend you to use this chance.
Nov 21, 2019 at 4:29 AM Post #17,944 of 18,020
I installed FiiO X7 Purist ROM version 3.3.9 V2 (Fidelizer) but it just stayed on the Fidelizer start screen and appeared to have stopped. So I installed the FiiO 3.3.9 firmware and it booted fine.
The issue I have is that the Pure Music and Android Mode switching doesn't work. I'll click on the button from the drop down menu and it will ask me to confirm if I want to switch to the other mode but nothing actually happens. It always just stays in Android Mode.
Has anyone experienced something similar? Any ideas?
Thank you.
Nov 24, 2019 at 9:47 PM Post #17,947 of 18,020
Nov 25, 2019 at 12:52 AM Post #17,949 of 18,020
I think we are talking at cross purposes here. Imagine you switch the x7 on in android mode, use the pulldown menu to go to pure music, is says android mode instead of pure music. It's the same the other way around. It still changes modes, though.
Nov 25, 2019 at 2:40 AM Post #17,950 of 18,020
Would that mean it is indicating the mode you would be switching to rather than the mode you are in?
Nov 25, 2019 at 11:05 AM Post #17,951 of 18,020
If you are in android mode and want to switch to pure music, you pull down the menu and instead of saying pure music, it says android. The same is true the other way round. It still changes correctly. It's just mislabeled.
Nov 27, 2019 at 2:47 AM Post #17,952 of 18,020
Dear friend,
It indicate the current mode you are using. And also, the LO/Spdif option work in same way.
Best regards
Nov 29, 2019 at 4:26 AM Post #17,954 of 18,020
Thanks for the reply. I thought it used to indicate the mode you were transferring to, so in Android mode, the pulldown menu would say Pure Music and visa Versa?
Dear friend,
In Android mode, the icon in pulldown menu shows Android.
In pure music mode, the icon in pulldowm menu shows pure music.
Best regards
