FiiO X7 | DXD | DSD | 384K/64B | ESS9018+ Android | WiFi | Bluetooth | 4 AMP modules | Balanced Out |
Nov 22, 2016 at 10:44 AM Post #15,301 of 18,020
oh man now I have to wait until I get v4a to be able to use neutron again, this is a bad position
FiiO told me V4A won't be compatible with the new SRC-bypassing modified audio stack structure of X7 on FW3.x until further notice.
But Neutron by itself does have powerful tone shaping options at least.
Try adjusting the first low shelf filter in Neutron like so:
1. go to EQ screen and hold the EQ button to bring up advanced menu (hold for a second then release; it won't pop up until you release your finger)
2. tap the cog next to "Band #1 (Low-shelf)
3. tap the Frequency, and Q radio buttons and adjust their numbers using the slider to read roughly as: Frequency: 1000Hz, Q: 0.3
4. tap the tick button on this screen and again on the next screen to confirm changes.
5. Now the leftmost EQ slider becomes a simple tone control slider, push it up to warm up the sound to taste.
Also maybe don't give up on V4A just yet--have you tried installing the latest version?
http://forum.xda-developers.com/showthread.php?p=68473076#post68473076
1. Open currently installed V4A, choose "uninstall driver".
2. Uninstall V4A the app itself.
3. Reboot.
4. Install the new V4A and reboot.
5. Go into V4A Settings, tap "Enter developer mode": tap OK to dismiss the warning the pops up.
6. Tap the new "Disable SELinux" item that appears; tap OK to confirm.
7. Try playing some music.
Nov 22, 2016 at 11:54 AM Post #15,302 of 18,020
3. Reboot.
can u please send me the new v4am because in the link I do not know why when I download it it downloads it as a zip file
thanks in advance
Nov 22, 2016 at 12:11 PM Post #15,303 of 18,020
https://www.dropbox.com/s/yf2gx1wrnrq6qq5/com.audlabs.viperfx-2.5.0.5-2505-78314.apk?dl=0
This is the link to the apk
I think the zip you downloaded is actually my new 3D IRS files for the new V4A
Nov 22, 2016 at 12:24 PM Post #15,304 of 18,020
thanks but unfortunately it did not work ,
driver: 2.5.0.4,  neon : yes, enabled yes, status normal, audio format: supported, processing: no
I followed your instructions to the point
I hope this will be looked at and solved as well
any other options?
Nov 22, 2016 at 12:38 PM Post #15,305 of 18,020
any other options?
Are you using the "generic" audio driver in Neutron's audio hardware settings? (you need to)
Nov 22, 2016 at 1:27 PM Post #15,306 of 18,020
yes I am using generic driver, I used kingroot 5 to root it and installed busybox
I am missing v4a
I hope fiio fix firmware 2 so I can go back to it
Nov 22, 2016 at 11:41 PM Post #15,307 of 18,020
Hello ALL !!!
Recently purchased the X7 combination with the AM5  , sounds absolutely supreme with my   AH-D600  . One of the threads on the player itself was missing , so having to return the whole thing . Also was not happy with playtime with AM5  .
Has anyone tried the X7 with the new A5 amp ???????? Any and all thoughts would be really appreciated !!!!
frank
Nov 23, 2016 at 5:27 AM Post #15,308 of 18,020
  Hello ALL !!!
frank
one of the threads was missing? what do you mean by that?
Nov 23, 2016 at 7:15 AM Post #15,310 of 18,020
The 2 pre- made screw holes that hold the screws that hold the  modules , one of those had no threading  ! Made it real hard , almost impossible to remove that screw , the screw would not back out as you unscrewed , like unscrewing a screw stuck in butter , lol .
Nov 23, 2016 at 7:26 AM Post #15,311 of 18,020
wow! that's surprising! first time i ever heard of that issue.
