Lanchez
- Apr 20, 2015
Have anyone tryed the X5 2nd Gen? how it would compare to a dx90?
Hello all and Happy New Year!
I recently picked up a pair of W40s, and am looking for a DAP that will complement them. No cans or other iems at the moment. I was planning to buy a K1 or a Q1 and connect to my iphone 6plus, but the types and lengths of cables (CCK and mini usb/usb) required would make the entire setup very cumbersome and messy so I scrapped that plan.
From my research:
From what I'm reading, both are very good products, with some minor differences in sound.
It also seems that the iBasso gear has a slightly more friendly UI than the Fioo gear.
DX have a replaceable battery, Fioo does not.
Lastly, should I even consider a unit with a built in EQ into my buying decision, in order to smooth the midbass hump the W40s seem to have?
Either the DX90 or X5 is within my reach (not willing to spend X7 money at this time), and I'm also willing to step down if suggested. I want something that will be "future" ready if I decide to buy some cans rather than something that will need upgrading again if the time comes. I'm leaning toward a DX unit at this time.
Can anyone offer some helpful guidance please?
From my research:
Are you planning to get the DX90 used? If not, you might want to look at the newer DX80, which should be around the same price as a DX90 since the DX90 is discontinued.
Anyway, if you look at my inventory I used to own a DX90, and my my experience with the equalizer wasn't really positive. I stayed away from it, since I found that it can muddy the sound when activated. Also, I used to have a Westone 4R, and I never found it to have an excessive mid-bass hump though![]()
Anyway, if you are only looking at the DX90 or X5, personally, I'd go with the DX90. It has superior soundstage size as well as detail retrieval. The X5, on the other hand, is more intimate and forward, with better depth reproduction.
But before I end, I have one last point for you to consider: The DX90's sound signature changes quite a bit with the firmware. It's quite a roller-coaster ride, I went between different firmware versions quite a bit until I found the one that I really liked - FW 2.0.0 - the best sounding but also the buggiest, and most difficult to use.![]()
If you are looking to buy a used X5 PM me as I have one for sale.
Thank you for the help. I noticed the DX80 the more I looked into the DX90, but thought nothing of it since it seemed to be a backward "progression" in their product linup numbering. I also read about the FW and issues on certain updates, and users downgrading their FW to the last stable version. Like you said, quite the coaster ride.
I don't want to sidetrack this thread so I messaged you an unrelated question.
