Tyke666
- Dec 14, 2014
Ok, so I watched a video online on how to place music on the X3/X5. I've been using Dapper to sync with my iTunes with some trial and error. You mean to tell me all I had to do was make folders named with my playlist and drag and drop the albums within that folder and copy it all onto the X5? Then I would basically have my playlists on the X5?
From reading your post, I can't work out exactly what you are trying to achieve (particularly what Dapper and iTunes had to do with it) so please excuse me if I have got it wrong with my following comments.
If you want to use playlists on the X5 (created elsewhere than the X5) then it's been discussed here - I don't think it's entirely straight forward so I never bothered myself:
How to Manually Create Playlists for the X5
If your playlists are just complete albums, and not random tracks from all over the place, then yes you could simply copy the albums or tracks you require into a folder named the same as your playlist, and just play that folder. But that seems to defeat the object of playlists though IMO.
Thats more or less the way I use the on-the-go feature. I just bang a load of tracks onto a 32GB card in one or two folders and play those.
