Fiio X5 - Custom/Modded firmwares
Aug 17, 2014 at 6:32 AM Post #272 of 2,613
Soundtrap
  Aztechno Beta 1.0 completed! (Based on Fiio Firmware release 2.0)
Use at your own peril, but know that I am currently using it just fine on my X5, no problems.
Let me know if you see any bugs and all that jazz.
In the next build I will redo the topbar which I'm not happy with.
https://www.dropbox.com/s/1o69oc9bnzfvjkw/x5.fw
Is it just me or this link for download is broken. Every time I try to download this theme, this link takes me to Matrix theme!? Does anybody have a clue what 's going on?
Aug 17, 2014 at 8:52 AM Post #273 of 2,613
CH23
I think that FlowerLandFilms had no folder structure in his/her dropbox and thus replaced the file by accident.
Aug 17, 2014 at 9:07 AM Post #274 of 2,613
Nicolas2305
Hmmm... How about the number of images used in the animations?
The main menu scroll wheel has 12 animation images (30° rotation each) and you have the images for each menu item. Their scroll direction is managed by a configuration file. I think CH23 mentioned it in one of his posts.
Aug 17, 2014 at 12:17 PM Post #275 of 2,613
darkarn
Hmmm I noticed that for the startup and shutdown animations, about 15 images are used. I am wondering if we need to stick to this closely (i.e. use only 15 images)
Aug 17, 2014 at 12:39 PM Post #276 of 2,613
CH23
Best way to try this out is creating more or fewer images, with each their image number on them, create firmware, try it out.
If i recall correctly you can use any number of images, but boot time will be the same. Don't quote me on this though, i might've mixed up the X3 and X5 here.
As for the "spinning wheel", you'll need exactly the number of images it currently uses.
Aug 17, 2014 at 12:46 PM Post #277 of 2,613
CH23
Yes, you need to look at the X5/coordinate/launcher.ini file.
If you unpack one of my later firmwares you can see which value controls which image (because that's all it is really. Image location on screen)
X = horizontal
Y = vertical
Only the first two "paragraphs" matter, image size doesn't seem to be regulated by this ini file.
Aug 17, 2014 at 7:28 PM Post #278 of 2,613
darkarn
Hmmm... Let's hope I can get the X5 soon!
Aug 18, 2014 at 4:20 AM Post #279 of 2,613
Flomet
@cooperpcw
Please can I ask if you are going to update FW 2.2 with your theme Aztechno Gold 90° rotated menu reversed scrolling.
This has been the only theme that I use and think it's really nice.
Many thanks to all the FW moders.
Aug 18, 2014 at 5:20 AM Post #281 of 2,613
Flomet
Aug 21, 2014 at 12:17 PM Post #284 of 2,613
CH23
http://www.fiio.pw/forum.php?mod=viewthread&tid=15200&highlight=x5%2B%E4%B8%BB%E9%A2%98
as it turns out, we weren't the only ones who figured that the X3 tools would work for X5...
translate.google.com will help you a lot on there :wink:
Aug 21, 2014 at 3:01 PM Post #285 of 2,613
bitseq
I had no idea there were tools to do this!
I may create my own theme now, I find the screen can be a little dark in daylight, so I have been thinking that a high contrast style theme could be useful.
Is this x3 firmware tools the tools you guys have been using? Are there any potential dangers with using these tools?
