FiiO X5 3rd gen Review Tour starts right now!!---Android based,Mastering Quality Lossless Playback Hi-Res Music Player
Mar 15, 2017 at 1:42 PM Post #526 of 677
Mar 16, 2017 at 4:23 AM Post #527 of 677
Hi
Code:
[color=rgb(33, 33, 33)] Unfortunately I found some problems: streaming from a nas is unusable; if you try to connect freezes and an error message; if you use music Hiby It works even if often disconnects. I have no problems with spotify. Someone has encountered the same problem?[/color]
Code:
[color=rgb(33, 33, 33)]  [/color]
Mar 16, 2017 at 4:55 AM Post #528 of 677
  Hi
Code:
Code:
Dear Pietruccio,
NAS may not be compatible with the X5III now. We will consider whether adding this function in the future.
Best regards
Mar 16, 2017 at 6:12 AM Post #529 of 677
@Pietruccio
I have about 75'000 songs on my Synology NAS.
To listen to the music, I installed the Logitech Media Server and use several Squeezeplayer to stream music to different rooms at home and to the office.
On FIIO X5-III I installed the Android SB Player and the Squeeze Ctrl apps.
With these apps, X5 acts as a Squeezeplayer and streams songs from the NAS like a charm ...
Mar 16, 2017 at 1:25 PM Post #531 of 677
Just checking in, has the cable been received by whomever I shipped it to?
It is showing delivered.
EDIT: Whoooops, wrong thread.:joy:
Mar 16, 2017 at 5:32 PM Post #532 of 677
Hi FIIO, I hope you have tested the mechanics of the SDtray ... It will have to survive at least 500 take outs each.
I have everyday something to add to the SDcard, and taking it out to transfer the files on the computer is the only way to do it in a reasonable time.
Mar 17, 2017 at 1:49 AM Post #535 of 677
USB audio player pro doesn't work streaming tidal. I get a lot of loud static in the songs. I couldn't even tell what was playing. Anyone else experience this?
FiiO has said they will get USB audio output working properly in a future fw update. I really hope they focus on it soon as it is an advertised feature.
Mar 17, 2017 at 12:08 PM Post #537 of 677
-Headphone(s) / earphone(s) you possess: UM Miracle, UM Mentor, Ultrasone ED8, Sennheiser HD800, beyerdynamic T1, Koss ESP950,Hifiman HE6, AKG K702, Sony EXK, Sony EX700
-Any DAP(s) / DAC(s) / amp(s) you may possess: Sony NWZ-A17, Ibasso DX100, Sennheiser HDVD800, Benchmark DAC1, Rudistor RPX-35, Oppo BDP-105D, Sony TA-A1ES, (Possible incoming purchase among DX200, DP-X1A and X5III)
-Descriptions and links to review(s) you may have posted: Many in the HD800, Koss ESP950 and HE6 thread, but lost track of them now.
-Your geographical region (e.g. the city and country you live in): Toronto, Ontario, Canada
-Your native language (and any other languages you may be able to write in) English and Chinese
Mar 17, 2017 at 7:11 PM Post #539 of 677
What exactly do you want to do with your NAS? What NAS do you have?
Every NAS supplier offer a software bundle to use certain functions.
Synology for example has a Media Server app, that turns the NAS into a UPnP / DLNA server.
Or they offer an Android app (DS music), that allows to stream music from an Android device.
It is not fair to say: streaming from NAS is impossible. It depends ...
And that's the reason, why Android on X5 is such a plus. I'm shure you'll find an app that does the job if you can't do it with the built in FIIO music app ...
