Preachy1
Welp, I'm done with the trial for GoneMad. Physical controls no workee. Not a big deal, I'm happy with either Hiby or the stock player.
Odd, they work for me.Welp, I'm done with the trial for GoneMad. Physical controls no workee. Not a big deal, I'm happy with either Hiby or the stock player.
i only use gonemad cor the x5, and it work Great and sound Great, love the next Shuffle Album optionGoneMad. Physical controls no workee
and the smart playlisti only use gonemad cor the x5, and it work Great and sound Great, love the next Shuffle Album option
I appreciate the crossfade, even among the albums. I don't have to replayigain very much. I prefer when music resembles a classic CD playback. 2 seconds between songs is just right, but crossfade is nice. From Neneh Cherry to Joe Satriani is an experience.and the smart playlist
GoneMad has a folder play and yoe can play next directory = setting - on queue completion - play next folder.I don't know any music player that can't play directories
After a few weeks of torture, testing - more torture, yelling at my family members because of frustration and just being angry, testing and yelling at my dogs (yes a 'simple' device can have this impact on people) I'm now fully enjoying my X5III and finally can just listen and enjoy some g'damn music! Yeah!
I was also a bit spoiled - using the iPod Classic for some years (which is just simple device that just works) and moving to the almighty FiiO X5 1st gen which is just awesome if you just want to play some music files of your SD card. Then I a few weeks ago I purchased the X5III and we all know that it's a slow monster and has some really strange quirks... I was almost selling this 'monstrosity' and use my trusty X5 1st gen again. Then I noticed that there were some clever people which created a modified firmware (Keetakawee) and even a custom kernel (jkbuha) so I was hooked and tried a lot of combinations (firmware, root, custom kernel).
I was unfortunate that my device uses a lower-grade RK3188 chip so the first week of 'torture' my device constantly reboots with the custom kernel... but jkbuha send me a modified 'modified' kernel which fixed the reboots. In the meantime I also purchased the Fidelizer Advanced Rom - so I installed it with the modified kernel but I was not a perfect match for me. So going back to the standard Fiio firmware with the modified kernel and everything was fine again. Fidelizer released his new rom based on 1.2.4 and I made the 'radical' decision to just install this Fidelizer version and just install one extra app - USB Audio Player PRO. This app is just genius! I plays my files perfectly (bit perfect), it plays Tidal files better then the Tidal app (even has MQA support) and 'Album Artist' support!
So I'm happy now. Only using USB Audio Player PRO which plays my files, Tidal, Radiostreams (from RadioTunes) and everything is super smooth and fast. It's tempting to push the most of your device but if you want to play Fortnite then buy a Nvidia Shield
I'm not using jkbuha excellent kernel right now (It's really awesome and you really must send him some beer money for his excellent work if you are using it!). After the weeks of my personal torture I finally have a device which is super stable, fast and just plays music.
"kaosnews"
Have you try neutron player? do you think USB Audio player is better?
Output thread AudioOut_4 Direct 0x41489300:
Normal frame count: 2560
Last write occurred (msecs): 32
Total writes: 2138
Delayed writes: 0
Blocked in write: yes
Suspend count: 0
Sink buffer : 0x415c6000
Mixer buffer: 0x415c9000
Effect buffer: 0x415ce000
Fast track availMask=0xfe
I/O handle: 10
TID: 11615
Standby: no
Sample rate: 192000
HAL frame count: 2560
HAL buffer size: 10240 bytes
Channel Count: 2
Channel Mask: 0x00000003 (front-left, front-right)
Format: 0x1 (pcm16)
Frame size: 4
Pending config events: none
AudioMixer tracks: 0x00000003
FastMixer not initialized
Stream volumes in dB: 0:0, 1:-24, 2:-6, 3:0, 4:-6, 5:-6, 6:0, 7:-24, 8:-18, 9:0, 10:0, 11:0, 12:0
Normal mixer raw underrun counters: partial=0 empty=0
2 Tracks of which 1 are active
Name Active Client Type Fmt Chn mask Session fCount S F SRate L dB R dB Server Main buf Aux Buf Flags UndFrmCnt
0 no 127 12 00000001 00000003 0 15360 I 0 44100 0 0 00000000 0x415c6000 0x0 0x000 0
1 yes 11648 3 00000001 00000003 13 10240 A 3 192000 0 0 005AF1A1 0x415c6000 0x0 0x000 0
Normal frame count: 8192
Total writes: 134942
Delayed writes: 0
Suspend count: 0
Sink buffer : 0x4161b000
Mixer buffer: 0x4157d000
Effect buffer: 0x4158d000
I/O handle: 4
TID: 535
Standby: no
Sample rate: 352800
HAL frame count: 4096
HAL buffer size: 32768 bytes
Channel Count: 2
Format: 0x3 (pcm32)
Frame size: 8
Stream volumes in dB: 0:0, 1:-6, 2:0, 3:0, 4:0, 5:0, 6:0, 7:-6, 8:-6, 9:0, 10:-43, 11:0, 12:0
1 Tracks of which 1 are active
none yes 27282 3 00000003 00000003 33 129024 A 3 352800 0 0 0054A000 0x4161b000 0x0 0x000 0
0 Effect Chains
