I downloaded trial version of Driver Genius. First scan doesn't even show missing USB driver here. Besides this is paid software.
Fiio X5 3rd gen || 2x AKM 4490 || Balanced Out || DSD || DXD | DTS | Android || Dual Card Slot
- Thread starter xLoud
- Oct 26, 2008
Has anyone else tried to "listen" to the Balanced out of the X5iii while attempting to Charge? I get a loud buzzing, so I have to unplug the power. It doesn't happen when using the SE out or the Line-out.
Bumping a pretty old post.
My X5iii has started to buzz/hum on one side in both balanced and SE outputs while plugged in or while just battery operated. Anyone experience this or have any way to try and fix it?
phred
- Feb 27, 2017
Does anyone have any experience using a single 512gb card in the X5-iii? I can't use two 256s due to the way my externally created playlists were created and I'm not about to redo 80+ playlists.
Thanks.
Thanks.
nekromantik
- Jul 30, 2009
the two way bluetooth sounds cool on the Shaling DAPs.
Shame fiio didnt include this.
Preachy1
that card is pretty new (and expensive) so not sure if anyone here has tried it yet, but i can tell you that my X5 handles two 400GB cards very well.Does anyone have any experience using a single 512gb card in the X5-iii? I can't use two 256s due to the way my externally created playlists were created and I'm not about to redo 80+ playlists.
Thanks.
geo626
- Jan 14, 2017
Anybody using tidal and get music stuttering even with offline music? Any solution?
https://www.head-fi.org/threads/fii...-dual-card-slot.828402/page-861#post-14084003
geo626
- Jan 14, 2017
blackdalhia
- Jan 25, 2017
Hi.
I have my fiio for more than one year now and starts to encounter to problems:
I copy files on the device but sometimes there are not visible, as if the copy was not actually performed
Sometimes I copy an album on the x5, it is visible and I start to play it but after 90 seconds there is no sound anymore and when I browse the folder I don’t see the tracks anymore.... I have to reboot the x5 to see the files again but the same issue happen again
Seems I cannot enjoy this device after one year which is not acceptable..... has anyone an idea what is happening here and how to fix it ? Shall I re format my sd card ?
takwing1hk
- Mar 14, 2013
Hi.
are you copying the file to SD card?
if yes, does this happen when you copy the file to the internal memory?
blackdalhia
- Jan 25, 2017
I will check it out but it seems it happens with only one of the two sd card.
I have been using the same two cards from the start
Fake cards let you write to them but files are not in folders
blackdalhia
- Jan 25, 2017
I am pretty sure it is not a fake. And until recently it was working fine
How is the dac section in this DAP compared to the best DAP's out there ? i know the amp is quite week but is not concern for me i have a quite powerful amp. As well for those that know how does the a5 compare to the objective 2 which one sounds better ?
Total: 16 (members: 0, guests: 16)
