Thx1326
- May 16, 2012
Since 3-4TB of FLAC files implies a HUGE collection, why not consider buying a couple of 200GB micro SD cards, format them as NTFS, and sift through your CD collection for your top 15,000 tunes (1000+ albums) as you rip the lot to an external hard drive. Gives you a chance to think about what you really like listening to & getting your album art & tags sorted & any playlists created. Personally, I would not rip directly to 320 but first go to FLAC middle compression. That way, if you want more than +15K tunes to play via BT in the car you can always & easily create a 320 version for on-the-go where top quality can't be full appreciated over road noise.
I have 2 - 256gb cards in mine - formatted with NTFS - very stable - no issues. Most of the music on my Fiio is Flac (highest compression level 8). Those that don't need to be lossless are in WMA VBR 440kbps. They sound very good on the Fiio and take up less than half the storage of the FLAC. Try listening to the same song in both formats and if you can't tell the difference - save the space.
I also use many of the Viper effects and settings with Fiio X9Pro IEM's. Great match up.
