Dobrescu George
Reviewer: AudiophileHeaven
Today I received the two cases that I ordered from Tuff-Luv. Shipping was pretty quick (2 days from London, UK to Waterloo, ON, Canada) but I got dinged for $29 in duty. The cases are feel like they are of good quality and workmanship. Each case also came with a screen protector. The X5III case feels and looks like it is made of thicker material and is, thus, actually larger than the X5III/A5 case. The fit in both cases is tight without being onerous.
Sadly, it looks like I won't be able to use the X5III/A5 case as I had hoped as it is designed to hold the A5 oriented with its connection ports at the opposite end from where the X5III connections are. So I'd have to replace the stock interconnect cable that came with the A5 with some other, longer cable that can wrap around the case. I'm pretty disappoint in that.
Nice!
Those cases look really snuggly!
I'm sorry to hear that you;re not able to use them together though. I wonder if they would correct their mistake if you let them know about it though.
