- Mar 30, 2012
Fiios Amps are pretty dark, that being said I expect the player might be [maybe not] Still I'm trying to get as bright as neutral as I can with my DAP choice. [Bright n Neutral without using eq's]
Also check out the Beyerdynamic Custom One Pro
I always recommend that people try out a device before deciding on its sonic character. It is very dependent on what you are driving. Calling the Fiio warmer than the Hifiman seems odd to me since the X3 is ruler flat and the Hifiman is 5dB down at 20KHz which is quite a bit of attenuation and should be very noticeable.
I have not listened to either though (I have an X3 on order).
