[FiiO UTWS5] True Wireless Bluetooth Earhooks as Usual,Coupled with Independent AK4332 DAC
Nov 27, 2021 at 3:35 PM Post #377 of 2,559
*not counting in the shallow area, so add about 5mm to D to the top of the lower case, another 6mm to D till it hits the upper case.
Thank you very much! Really useful!
Nov 29, 2021 at 3:04 AM Post #378 of 2,559
Hey @FiiO , when will this become available on Amazon or even on AliExpress? I have placed my order on November 17, and it is still in processing. I've asked the store, on AliExpress, and all they said was: At the end of the month, the factory will ship. Will you?
Can you provide an ETA, please?
Thanks for your interest in our product. The UTWS5 is available now in our Aliexpress store: https://www.aliexpress.com/item/1005003605804776.html
And it will be arranged to our oversea sellers successively.
Best regards
Nov 29, 2021 at 3:09 AM Post #379 of 2,559
DoH! :relieved: :smiley:
Hopefully the UTWS5 MMCX comes with one.
It does not come with the UTWS5. But you may contact the seller to see whether he could give an extra one for you.
Best regards
Nov 29, 2021 at 4:46 AM Post #381 of 2,559
Nov 29, 2021 at 5:57 AM Post #383 of 2,559
I saw that. Thank you for your measurements! But I don't have a CIEM yet so I actually am not sure how large they are.
How large a CIEM is determined by both the inner drivers number/size as well as the size of your ear canal + outer ear. So even for the same model, different person will have a slightly different CIEM mold / size. Maybe another person's CIEM can fit but not yours. It all depends.
Nov 30, 2021 at 11:51 AM Post #384 of 2,559
Just 'discovered' that the BTA30 Pro was released some time ago and reading the specs and compare to the BTA30 I have.
Hell, if we could convince FiiO to release a UTWS5 Pro with aptX-LL, HD and whatnot, I would happily pay a premium $$$ for it.
Cheers
Nov 30, 2021 at 12:05 PM Post #385 of 2,559
Cheers
Not gonna happen since Qualcomms newer TWS chips doesn't support APTX LL.
I
Nov 30, 2021 at 1:00 PM Post #388 of 2,559
@FiiO I can't really see it from the pics but does the UTWS5 have recessed 2 pin sockets? Or are they flat or even protruded?
Tnx...
drftr
On page one in this thread you can see they are using MMCX.
The 2 pin version has pins just sticking out of the round ear hook. That means that IEMS like the BQEYZ BQ3, which have a recessed 2 pin opening - that will not work.
Every IEM with a flat or raised 2 pin will work.
Cheers.
Nov 30, 2021 at 1:26 PM Post #389 of 2,559
Thanks. Will give them a pass in that case
Cheers.
Thanks. Will have to give them a pass in that case. I think the quality and sustainability of the connection should be top notch for devices that are used every single day. And adapters don't really seem to work well after reading some true horror stories over at the HifiGuides forum (think pins breaking off and sticking in IEMs permanently, rendering both completely useless).
drftr
Nov 30, 2021 at 2:30 PM Post #390 of 2,559
Your post is obnoxious.
Nobody forces FiiO to use the newest Qualcomm chip, they could also choose to use something else. They switched the DAC chips from AK to ESS as well and its not going to break their back.
All right, so who will manufacture Qualcomms old chips then?
Are you really that stupid?
You can't compare the DAC-chip with the SoC...
