thefallenangelx
Ok. In short i should not care about what poweramp says?BT codec is indicated by LED color / pattern. It has nothing to do with what poweramp (or any music app) is saying on your smartphone. What poweramp is indicating is the bitdepth / bitrate that it is outputting to the BT adapter. It has nothing to do with what BT codec is used between the BT adapter and UTWS5.
For example, people thought because Apple uses mainly AAC as its preferred BT codec, so if you are playing AAC music files on Apple devices, then it will be sent completely intact to the BT receiver (*headphone, etc). That is however a completely incorrect understanding how BT works. The AAC music will first be decoded back to PCM stream, then sent to the BT adapter (or BT chip), re-encoded to AAC and send over via BT to the receiver, then re-decoded back to PCM and convert to analog sound. So even though AAC music is played over BT devices that used AAC as BT codec, the two processes really don't have much to do with each other. The same applies to any music files vs. whatever BT codec is used. Whatever the music app is outputting and whatever the BT adapter is outputting don't concern each other.
But in this case, does it means that poweramp stream to the usb DAC in 16bit and then the DAC upstream via BT to the UTWS5 in 24bit?
Looks like there is a downscaling first and then upscaling, potentially degrading the sound stream?
