Ya they said it will be here within a few weeks and is coming for sure on these.Thank you… but are you sure that Transparency mode is coming?
I thought FiiO mentioned it wasn’t before, or perhaps I am wrong…
Would love more thoughts from you on experience using UTWS5 with iPhone. When you pair them do they pair as one device or separate L and R?
[FiiO UTWS5] True Wireless Bluetooth Earhooks as Usual,Coupled with Independent AK4332 DAC
- Thread starter FiiO
- Tags
- fiio fiio utws5
Ambient mode is coming to UTWS5, as confirmed by FiiO. It is NOT coming to UTWS3 because of hardware issue...
voicemaster
Neck adapter sucks!!I don’t understand how all the neck BT adapters have AptxHD and LDAC and no TWS adapter has anything past Aptx…
At this point cost/performance ratio would be better to buy a necklace adapter then.
As far as I know it’s because of the size on the Bluetooth chip from Qualcomm. The utws5 has the best chip that it can fit.I don’t understand how all the neck BT adapters have AptxHD and LDAC and no TWS adapter has anything past Aptx…
Will the utws5 come before christmas?
drftr
Can you elaborate please? I was thinking adding that as a potentially better option so I'm curious what I can learn...Neck adapter sucks!!
drftr
BlazdiqFoods
Is Aptx Adaptive good enough for FPS gaming? Like CODM
voicemaster
Not talking about the specs and sound quality, but the form factor just sucks imho.Can you elaborate please? I was thinking adding that as a potentially better option so I'm curious what I can learn...
drftr
drftr
Because how it moves by itself? Or cable restrictions perhaps? I've never used them and prefer to learn through others' experiences instead of blind buying and finding out it doesn't work for me.Not talking about the specs and sound quality, but the form factor just sucks imho.
drftr
C_Lindbergh
Not for competive playing imo, but it's fine for most other games.
*not counting in the shallow area, so add about 5mm to D to the top of the lower case, another 6mm to D till it hits the upper case.
drftr
Do you people normally have to bend the IEM/cable to get them in? I'm worried using it with 2 pin connectors.
drftr
drftr
@FiiO
Are the ear hooks interchangeable? Meaning, I can buy a 2-pin unit and separate MMCX ear hooks and swap when I want? Please say yes.
Otherwise, I can get these (link below) and pair with a MMCX unit. Although, I really hate MMCX. Can't tell you how many cables I've broken trying to get the MMCX connectors apart.
https://www.amazon.com/OEAudio-MMCX-0-78mm-Adapter-Clear/dp/B07XPF1BL5/
drftr
A
https://www.fiio.com/newsinfo/504771.html
drftr
Assuming you're not familiar with FiiO's own tool then?
drftr
Total: 6 (members: 0, guests: 6)
