[FiiO UTWS5] True Wireless Bluetooth Earhooks as Usual,Coupled with Independent AK4332 DAC
Jul 18, 2023 at 3:45 PM Post #2,281 of 2,576
Flashed 1.73 at the end of last week, and for a few days it looked like this had fixed things. But this evening I found that the R earhook had connected to my phone sometime during the day and managed to drain its battery. The L had not connected and was fully charged. Both earhooks have been sitting in the case sitting on my desk, so there's no chance the top came open.
@FiiO : Unfortunately your engineers need to look at this issue further. This is by far the most annoying aspect of this device.
Jul 18, 2023 at 9:58 PM Post #2,282 of 2,576
Dear friend,
Please try to clean the charging pins of the UTWS5 and clear the pairing to check again first.
If the issue remains, please contact support@fiio.com with the receipt attached. Thanks in advance!
Best regards
Jul 18, 2023 at 11:27 PM Post #2,283 of 2,576
@FiiO
With your latest firmware 1.73, I cannot adjust the volume when I am pairing my UTWS5 with my BTA30 Pro.
I have a second pair of the UTWS5 which still runs firmware 1.5 and this one works fine. When paired with my BTA30 Pro, the volume can be adjusted from the ear-hook buttons.
Can you try this, yourself?
Can you offer a solution?
PS: The volume adjustment, as well as all the rest, functions as intended when paired with my smartphone. The issue is only with the BTA30 Pro.
Dear friend,
We have reported to the engineer and they will have a check first.
Best regards
Jul 19, 2023 at 3:52 AM Post #2,284 of 2,576
Dear friend,
Best regards
Thank you!
Looking forward to your findings and solution.
For the record, the only two UTWS5 functions that have ever worked with the BTA30 Pro are Volume adjustment and Play/Pause. Next/Previous song has never worked. Now, however, not even the volume adjustment works. Play/Pause still works with the 1.73 firmware, though.
Jul 19, 2023 at 7:23 PM Post #2,285 of 2,576
20 minutes of play time after charging overnight:
I thought the issues were finally ironed out. I've been on this firmware for a week and the problem just started. I tried clearing the pairing etc. but it doesn't help.
My first UTWS5 didn't even charge, it was DOA. And now this. Disgraceful.
Update: 20 minutes later.
They both started at 100%.
Update 2: After charging both sides back to 100% and listening for half an hour:
Jul 20, 2023 at 6:51 AM Post #2,286 of 2,576
@FiiO
I think most of the critical issues have been resolved since version 1.73.
My only complaint is that the volume in transparency mode is still too low compared to 1.5.
Can I ask you to fix that issue?
-- Additional
For those who are still having issues after the 1.73 update, I leave the procedure I tried.
1. The settings from each version (1.4, 1.5, 1.7, etc.) seem to be preserved after the update. When I update, the settings seem to be reset, but when I downgrade, the old settings are still there. I suspected that these saved settings were having an impact.
2. so I downgraded to a firmware I've used before, put it in a case, and did a factory reset 2-3 times, repeating the process for both 1.4 and 1.5.
3. I then updated again to 1.73 and repeated the factory reset by putting it in the charging case for another 2-3 times.
After that I no longer experienced the issue of it connecting when charging was complete.
It does charge to 89% when battery protection mode is on, unlike 1.5, but it's not a serious issue.
In 1.5, there was an issue with EQ settings being reset frequently, but this has been resolved in 1.73.
Jul 20, 2023 at 10:19 AM Post #2,287 of 2,576
I think the battery is ruined?
Jul 20, 2023 at 7:32 PM Post #2,290 of 2,576
The actual reason (at least I think it is the one) is that Samsung used AOSP Bluetooth stack instead of Qualcomm's one, probably because of SSC.
I guess it would be possible to do something about this with root (it's possible to get LHDC on Red Magic 8 Pro according to this xda thread, and it didn't support LHDC initially), so maybe there's a way to get QHS working on Samsung phones as well. But it will require root, is the bootloader even unlockable on Samsung phones? Maybe you can ask author there if it's possible.
Or I hope in 1 or 2 year more custom rom will be available, I think aosp rom support lhdc, ldac and aptx hd
Jul 20, 2023 at 7:48 PM Post #2,292 of 2,576
AOSP-based ROMs aren't good in terms of using all the hardware features (especially for Snapdragons), so CLO-based ones are better. And there are exactly zero CLO ROMs with LHDC right now (tho Paranoid Android might become one of them soon).
Jul 20, 2023 at 10:50 PM Post #2,293 of 2,576
@FiiO
-- Additional
Dear friend,
Thanks for the kind feedback. We have reported to the engineer for checking whether they could improve the volume level in transparency mode.
Best regards
Jul 22, 2023 at 10:40 PM Post #2,294 of 2,576
Is the UTWS5 still in production?
It seems very hard to find a seller in europe who has it in store as 2 pin version.
Jul 23, 2023 at 9:05 PM Post #2,295 of 2,576
Dear friend,
If you are located in Germany, you could contact the local distributor to check when they will have the 2pin version in stock again:
mail: support@fiio-shop.de
tel: ++49(0)42170508619
Best regards
