stephenk1982
Where do I find firmware version 1.73?
Online upgrade only says 1.5 is newest for me
Dear friend,Where do I find firmware version 1.73?
990kbps has worked for me... But struggles in places like a Gym. I'm guessing coz so many ppl about with Bluetooth and phones. But obviously I've no idea why.Does anyone try LDAC mode on Samsung S22/s22ultra (exynos chip) ?
Looking for tws adapter for letshuer s12 pro, trying to decide, does it worth to buy utws5 instead of az09 pro for samsung s22 ultra phone and ax210 laptop.
Have read the previous few pages, but still don't understand, can I expect at least 660 kbps or 990kbps 24/48 modes ?
FiiO's experimental LDAC does not work on my Samsung S23 Ultra. I have tried various settings but got so disappointed that now I am using aptX with my UTWS5. No issues at all with my iFi GO Pod, I have rock-solid LDAC 990/909kbps.Does anyone try LDAC mode on Samsung S22/s22ultra (exynos chip) ?
Have you turned it on in the 3 different places?FiiO's experimental LDAC does not work on my Samsung S23 Ultra. I have tried various settings but got so disappointed that now I am using aptX with my UTWS5. No issues at all with my iFi GO Pod, I have rock-solid LDAC 990/909kbps.
Yes, I have. But I don't have good and consistent results. It might play for half an hour, or so, and then I am getting crackling noises and artifacts. The UTWS5 works great on LHDC for me, on my other phone, a POCO F2 Pro. That's how I've been using it before getting the S23U. With the Samsung, FiiO LDAC does not work for me.Have you turned it on in the 3 different places?
Developer settings, the bluetooth connection and the fiio app?
Hi @FiiO@FiiO
With your latest firmware 1.73, I cannot adjust the volume when I am pairing my UTWS5 with my BTA30 Pro.
I have a second pair of the UTWS5 which still runs firmware 1.5 and this one works fine. When paired with my BTA30 Pro, the volume can be adjusted from the ear-hook buttons.
Can you try this, yourself?
Can you offer a solution?
PS: The volume adjustment, as well as all the rest, functions as intended when paired with my smartphone. The issue is only with the BTA30 Pro.
Did you listen it on S22 exynos or snapdragon ?990kbps has worked for me...
This has since happened another two times. I contacted your support email and recieved a reply from someone who had no knowledge of the issue (despite the months of complaints here from numerous people).Dear friend,
Please try to clean the charging pins of the UTWS5 and clear the pairing to check again first.
If the issue remains, please contact support@fiio.com with the receipt attached. Thanks in advance!
Best regards
Read my post sharing my experience above. My conclusion to the issue is probably physical defectThis has since happened another two times. I contacted your support email and recieved a reply from someone who had no knowledge of the issue (despite the months of complaints here from numerous people).
It's time you started taking this matter seriously. The alternative is that this is actually a hardware problem (possibly with the poor charging pins used) which you can't fix.
