thedanadamsusa
Also, are you successfully using LDAC at its highest setting?Got mine!
Sounding great with Traillii, Mason FS, Trifecta and Ronin. very happy with them and how they work with my iPhone 13 Pro Max.
Thanks!
Hmmm… I have my Go Pods set for 990 and stereo, connected to my S22 Ultra. Other than the odd cutout (which I have come to expect with any LDAC item), it is working fine for me…. What symptom should I be looking for?
I will try to connect with my R6 Pro II and see if I have a different experience.No idea how Samsung smartphones work as I haven't had one for over a decade, but my Go Pod just suffers from completely stuttering when switching to SQ Preferred (with Xperia 1 IV). As said in the previous post, the same happens with Shanling M0 Pro and M1s. Also just tried with FiiO M6, the same thing as well - completely stuttering with SQ Preferred but fine when switched to Best Effort.
I can think of a few possibilities in your case: Somehow Samsung has either 1) a more efficient LDAC transmission rate that allows it to circumvent Go Pod limitation, 2) internally lower the bitrate to 660kbps without notifying the user or 3) sending out mono or even joint stereo signal.
Anyway, I think you can try playing back some left/right channels' test music (plenty on youtube) and see if it reveals anything noticeable.
Really strange and surprising .. unless all my Android 13 connexion info are wrong.I got a reply for why my Go Pod is so unstable when running LDAC 990kbps, and I am both shocked and speechless.
Don't mind the link that said NEO Stream, it actually does point correctly to GO Pod manual, which you will find on the footnote on page 5:
Just WOW. Only mono is supported on LDAC 990kbps? Seriously? I have UTWS5 (same QCC5xxx series chip) on LDAC 990kbps with Stereo without any issue, so what is iFi excuse for not supporting it? I didn't even find that footnote anywhere on Go Pod's product page on iFi Audio website. Arguably it SHOULD have been front and center on the product page and served with a warning sign no less, but nothing instead. True shame.
The sad part is perhaps my Xperia 1 IV doesn't even support mono with TWS (True Wireless Stereo, oh the irony there), so no luck for me on LDAC 990kbps.
Iphone doesn’t support LDAC, only AAC.Also, are you successfully using LDAC at its highest setting?
Thanks!
Hard to tell, since I use the Go Pods on the move and cables when I am using my DAP.I’m very tempted to try these with my Trailii. How much of a difference are you hearing between using the Go Pods and with the PWAudio cable connected?
Let us know when you Sennheiser compatible adapter arrives - would love to see a photo with the IE 600 connected.actually yes, IF you get a pair with their newer revision mmcx cable. I just emailed support, they said MOST of the mmcx cables out there are the newer revision that works with the IE series, but if yours doesn't, they will send you one under warranty. The initial batch did not work with the IE series, but they fixed it during manufacturing.
I am finally getting mine sent to me actually.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
I see - think I misunderstood, you’re only using the GO Pods with you iPhone? If using your DAP, it’s always a wired connection?Iphone doesn’t support LDAC, only AAC.
We have a winner. These OE adapters resolved my comfort issues and still fit the case with this iem
