Ask Samsung. I have no clue why would they do that. Probably to make people buy their earbuds instead.Why is this happening? Am I looking at the wrong place or something?
How they did that? Well, simple. Instead of using QTI Bluetooth stack from here they used AOSP stack (with some modifications as it seems, mainly for SSC)
Not really.this Snapdragon Sound has to do with Bluetooth Low Energy Audio (LE Audio)
Yes.and the new aptX Lossless Bluetooth codec
Because they did (well, it's quite a bit more complicated than that, but let's not go into details as it doesn't matter). The point is, the QCC5141 chipset in UTWS5 basically said "F you, I'm not gonna work as you want". Qualcomm f-d up high bitrates in their fancy TWM. Same for LHDC, but here they can at least disable 900 kbps mode. Unfortunately, I don't know what exactly is the problem, but I'd assume it's caused by buds communicating to each other and taking some of that precious bandwidth.So, why has not @FiiO implemented the "normal" LDAC codec in a correct and appropriate manner for the UTWS5? Why is LDAC so buggy and erratic?
It's not LDAC itself who is to blame, but rather the QCC5141 and its firmware, which is a real mess. Some parts are binary blobs, so FiiO simply cannot do anything about that without help from Qualcomm. And, as you might imagine, they are not helping much. AFAIK some of those issues were reported to Qualcomm, but no fix was provided. The 990 kbps issue isn't probably going to be resolved, but some others hopefully will.
