ext23
- Sep 8, 2010
Will there be more firmware updates for the UTWS5? Still hoping for LDAC...
Which phone are you using? It's expected behavior if your phone doesn't support QHSBuggy as Hell on the FW5's over 660k, 990k stutters the longer it plays till it is unusable till you reconnect.
My phone does not support SnapDragon (FiiO do not claim it has to but do mention it can help due to the bandwidth), Andprid has had Android support for years well berore SnapDragon and all others work inc my FiiO's neckband.Which phone are you using? It's expected behavior if your phone doesn't support QHS
But they all are not QCC5141 TWS devices unlike UTWS5/FW5, the good experience is only possible with QHSAndroid support for years well berore SnapDragon and all others work inc my FiiO's neckband
Any improvement in sound, you noticedI can happily report LDAC at maximum settings working fine on my Xiaomi 12S Ultra and 13 Ultra (with Snapdragon Sound). I will try on non Snapdragon devices and update later.
Yeah, same here with the electrostatic and loos of signal noises. But, switching to balanced becomes more stable. I have not stress tested it for more than about 90 minutes. I shall dive into it deeper when i have the time. Testing with Fold 3 and the M17.Exactly what I am experiencing. After maybe like an hour or two, I am starting to hear "tsk-tsk" noises, like sound artifacts. I am using the LDAC at balanced/best effort on my Samsung S23 Ultra.
