[FiiO UTWS5] True Wireless Bluetooth Earhooks as Usual,Coupled with Independent AK4332 DAC
May 29, 2023 at 12:33 PM Post #2,086 of 2,559
@FiiO Which exact pogo pin type do you use for the earpieces? On my UTWS5 they are corroded after a year.
Pogo pin is ~ 7.3mm long, 2mm thick on the thickest part, 1.5mm thick on the contact surface side.
The the battery also needs to be replaced, right now I´m putting in the battery of my less used MMCX UTWS3 and use it´s backplate where the contacts are still fine.
(I used it daily, battery protection for a 85% charging limit was activated all the time)
May 30, 2023 at 4:10 AM Post #2,087 of 2,559
Dear friend,
Did you buy the UTWS5 from the local seller in Germany? If yes, you could try to contact the distributor in Germany for help instead of repairing by yourself:
mail: support@fiio-shop.de
tel: ++49(0)42170508619
Best regards
May 30, 2023 at 4:48 AM Post #2,088 of 2,559
No, I bought it from the „FiiO Retailer Store“ on Aliexpress. And now the earpieces are opened anyway :)
May 31, 2023 at 11:38 PM Post #2,090 of 2,559
Ey @FiiO !
Any chance to add more volume steps on the UTWS5? Using with the FH5, and I would like to get a more precise volume.
Thanks!
Dear friend,
We will report to the engineer for assessing first.
Best regards
May 31, 2023 at 11:45 PM Post #2,091 of 2,559
Dear friend,
Can this help:
弹簧探针D2.0*7.2立式单头(插脚1mm,行程1.5mm)压缩1.0时25gf平底针头镀金
Best regards
Jun 1, 2023 at 7:23 PM Post #2,092 of 2,559
I got a second one of these after the first one went haywire.
The second one is also useless: the charging case doesn't hold any charge and can't charge the hooks. It just pulses constantly when it's plugged in. I tried all sorts of different cables etc. and even let it charge overnight. Totally unresponsive.
I live in Japan and can't find any way to return these two products because the post office and the shipping companies both refuse to send lithium ion batteries.
Money down the drain.
Jun 3, 2023 at 4:33 AM Post #2,093 of 2,559
@FiiO
Are you planning to offer an upgraded model of the UTWS5 until the end of this year or until March, 2024?
Jun 5, 2023 at 2:26 AM Post #2,094 of 2,559
@FiiO
UTWS15 ((NEW), expected to be available in the fall
The UTWS15 is the upgrade model of the UTWS5. The core architecture of the UTWS5 is still the one with the best sound quality among TWS products, because ordinary TWS products still choose the integrated DAC, which has weaker audio performance than the independent HiFi DAC used in the UTWS5. Even for the new TWS from vivo, we later got to know it used an independent DAC because it is attached to the noise cancellation function, but not using it for better sound quality like us.
So, the main progress of the UTWS15 is in some details of the experience, such as the size and weight of the charging case, the size and weight of the ear hook, as well as the new design of the contact connection. Old UTWS5 users are not necessary to upgrade it.
Best regards
Jun 5, 2023 at 9:45 AM Post #2,095 of 2,559
Best regards
Thats great and all, but what is @FiiO doing to improve integration with the mobile app? Its great to keep coming up with new hardware but I would implore that the software integration is vital to a product targeted to audiophiles. While the normal consumer would not care about EQ or filters etc. but many, if not all who purchase FiiO TWS products would expect some ability to tweak the sound to their preferences. Many on this thread have said that the Qudelix mobile app is the best mobile experience in the industry and that @FiiO could benefit by creating something similar for their UTWS line. However, these comments have largely been ignored by @FiiO.
Its frankly disappointing for @FiiO to ignore comments about their horrendus app but keep pushing out new product.
Jun 5, 2023 at 11:13 AM Post #2,096 of 2,559
What is the number for the lipo battery? Photo wasnt clear enough
Jun 6, 2023 at 1:53 AM Post #2,097 of 2,559
381218, 3.8mm thickness, 12mm width, 18mm length. Same for UTWS3 and 5.
Closest that I found where „80mAh“ 351018 cells on aliexpress that are on the way to me.
Jun 6, 2023 at 2:26 AM Post #2,098 of 2,559
Dear friend,
What's your problem with our App in UTWS5? Different products may have different functions so some functions in the app for certain products may not be supported in UTWS5.
Best regards
Jun 6, 2023 at 11:38 AM Post #2,099 of 2,559
Trying to update my UTWS5 to v1.5 from 1.42. iOS. Have tried twice via OTA. Now trying via local. How long should it take on the 'Updating.....The firmware is in preparation, please leave in this page' screen?
On the OTA tries, I waited on that screen 10 minutes. Now, on the local update try.....it's at 15 minutes. I have the iPhone set to NOT sleep, and I haven't switched away from the app.
Jun 7, 2023 at 5:06 AM Post #2,100 of 2,559
Dear friend,
Does the update work now? If not, you may try to reset the UTWS5 or use another mobile phone to check again.
How to upgrade the firmware of UTWS5: Click here
(Video instruction: Click here)
Best regards
