ext23
- Sep 8, 2010
I get about 5 hours on aptX. Is this OK?You could try to check the how long can the UTWS5 work after fully charged?
The battery life for your reference:
>8h (AAC)
>8h (AAC)
Dear friend,I get about 5 hours on aptX. Is this OK?
Also my unit shows at 95% immediately after a full charge...Please try to set the volume of your mobile phone to max, then adjust the volume via UTWS5 to test again. It seems that the battery life is abnormal.
yes, but I reccomend waiting FiiO will fix the very annoying issues first and only then buy it.I saw on aliexpress an 2.0 version from Uwts5? Is original? Which are the changes? Only charging contacts?
Which ones? Do you have one?yes, but I reccomend waiting FiiO will fix the very annoying issues first and only then buy it.
I have v2 and it sporadically connects to my phone when it stays in the case, loosing the eq settings when I charge the case with iems inside.Which ones? Do you have one?
Android or IOS?I have v2 and it sporadically connects to my phone when it stays in the case, loosing the eq settings when I charge the case with iems inside.
Android, but I think it doesn't matter.Android or IOS?
Hi, I bought my utws5 un february, brand new. Do you know how can I Tello if they are V1 or V2?I have v2 and it sporadically connects to my phone when it stays in the case, loosing the eq settings when I charge the case with iems inside.
Dear friend,Hi, I bought my utws5 un february, brand new. Do you know how can I Tello if they are V1 or V2?
I have a very annoying issue where the right Hook Is not charging. When Places on the case sometimes Is undetected and sometimes it turns its light on without flickering, as if the Unit was completely charged. I've read plenty of similar cases online, no fix.
