- Sep 5, 2010
also keen to know if December still eta?
I am hopeful the special edition will be bass heavy or at least have a significant bass boost option.
Maybe some deep sub bass too. Earthquake bass
Due to nearly none, but about 2-4 DACs supporting the ability to skip the built-in DACs within devices, such as the iPod Classic, would it then be pointless to get an E17 and instead get an E12?
It depends. If you are only using as part of a portable setup, I would suggest the E12. If you are looking for more versatility from a DAC/amp and would like to connect to your PC or other device along with the option of portable use, then I would suggest the E17.
What would the SQ be like?
Over the past few days, I've only begun looking into amps., DACs and amp. + DACs [single units], etc. Therefore, please go easy on me!
Thanks!
...and yes; I must agree with Bowei's point on the charging. If a change could be made to allow for that, it'd be much better.
I agree with Craigster75.
I have an iPod Classic, and will connect it to the E12 using the line out dock. This will make a good solution. However I will not be using IEMs.
I want as much power delivery, hence why I'm not going via the E17 route.
So the E12 will provide more power than the E17? [...and in the SQ department, what would things be like? - Not just SQ, but also sound signature, how spacious it sounds, too]
Hmmh... I suppose that it may be better to get the E12 than the E17. If I were to use the DAC from the E17 [outside of a portable setup], it'd only be on rare occasions.
P.S. Would you mind having a look at my thread that I've posted in the Portable Headphone Amp. forum?; I'd be really grateful.
Thanks!
Thanks!
When can we start ordering this amp?
