Stoney
- Sep 15, 2003
Sure, all I need is a loaner E12.
You may find old iPod chargers and some iPhone chargers with the same shell (and a lower wattage). These power adapters won't damage the E12. I really don't know if a 12V or 13V power supply can damage the E12. I've never seen an electrical appliance that can adjust the input voltage requirements automatically depending on the power supply in use (it should be noted that the E12 should be fed with a 14V power adapter).
I'm really starting to wonder what kind of power adapter it is lol. I've found infos about some even older and bulkier power supplies which had a 13V/650mA output but those things used firewire ports instead of USB.
Only use a charger that OUTPUTS 5 VOLTS.
If you read the previous posts you'll see we already know that. The recent iPod/iPad/iPhone chargers output 5V (up to 5.2V on the most recent 12W power adapters).
I am still wondering what kind of power adapter Dyaems owns, I'm not sure about its output voltage.
Anyone want to do a Headstage Arrow vs E12?
@Chris J: Yeah, I'll blame it on the iPad.
What I wanted to say was that recent power adapters follow the 5V output standard while Dyaems probably owned a 12V/13V output charger like the old iPod dock-to-firewire chargers (Probably a 12V power adapter will damage the E12, however I'm not sure). The E12 can be powered either via 5V DC output and 14V DC output power supplies.
Anyway, after some research I'm quite sure Dyaems' power adapter is the A1102 model.
5V DC 1A. There should be no problem at all!
if i can compare the E12 and the arrow, and the arrow is only based from what i recall, tonally, the E12 is more balanced, bigger soundstage, than the midcentric and soundstage-collapsing headstage arrow. feature-wise and size, the arrow wins hands-down.
Originally Posted by MrScratch /img/forum/go_quote.gif
-snipped some parts-
-snipped images-
is this worth getting if you already have an E11?
I don't follow. I don't have an E12, but the Arrow is an amazing amp in terms of making instruments sound "whole" and 3D, as opposed to some amps that sound "hi-fi" with highs that seem dismembered from the midrange, or at least a tendency to sound uncomfortable compared to the Arrow.
The Arrow sound does depend on the gain setting, and on headphone impedance, so if you test, use more than one... I used 47ohm PFE 232 and 600ohm HD650. The gain setting for these makes a huge difference, which is common if the gain is changed by changing loop feedback, and if output impedance (which changes with feedback) is not low enough such that gain changes don't cause output gain-related variations.
In my tests, the middle gain setting sounds more full in the midrange than the low gain setting. Two points: the midrange sound more realistic, not just more full. And, the treble is more realistic, less emphasized, with the middle gain setting. That is the only one I use.
Comparing the Arrow with E17, the only FiiO that I have, shows it to be far superior in high-end realism, although the E17 is more hi-fi in detail retrieval but in a false way that grates over time. (The DAC in the E17 is pretty good though.)
P.S. not sure if you really own an HD650 as the hd650 only has 300 ohms, so ill correct that for you
E12 trumps all over the E17's amp section, and everyone who owned an E17 during our meets said that when comparing the E12 and E17.
i also want to mention that i also posted my short impression on the arrow 4g thread a few pages back. maybe you dont want to see the word "conjested" as it looks like a negative word, so ill replace it by the word " too intimate"
you will possibly say something like "we all hear differently", yes its true, but my impressions will surely be "stronger" as it is backed up by alot of people who tried and heard during meets/minimeets, not by just reading reviews in the threads here.
