abitdeef
Formerly known as ihatepopupads
- Oct 30, 2003
I think fiio is learning fast from hiby how to top customer service
Lol.
Lol that was my first and last experience with Hidizs. Yes they basically disappear once they have your money and are horrible on firmware updates. I sold mine due to poor hitbox detection having me to hit buttons several times. It did sound nice, but m6 still has a wider stage and it had magic 8 ball dsp to adjust the sound bit it and the company seemed half ass.
Build quality on mine was ok - although you could still see polishing grit in the grooves on the back (very sloppy), but I guess some people’s scroll wheels were very loose and some fell off, and with the poor customer service... Well you see where I’m going, I wouldn’t recommend them my friend no no no. I’d take M0, A55,R3, and definitely m6 over the AP80.
I guess there are people with models from them (Hidizs) that are several years old that never received promised features, and firmware support is non existent. Unless they miraculously improved over the last month- haven’t followed the AP80 thread.
I stand behind m6 it’s a great dap and the niggles I have with it well they are about streaming tidal which won’t effect you. Other than that it’s a fantastic dap.
I love Sony, because they always have a great sound stage and a meaty sound and great battery life, but I really like the ESS based Sabre sound, and have grown really fond of Spotify. I like m6 so much I purchased an amp to run through it so I can dust off my sennhieser hd600’s.
I’m also thinking about getting the Sony1000mx3 to use with m6, they sound fantastic and are seem really comfy- one of the few things I got to demo at the Sony store. I’m actually listening to wireless LDAC from Spotify on the m6 as I type this and it sounds amazing! Lol I’m rambling but no I can’t in good conscious recommend the AP80 it’s got some nice features and good sound but it’s iffy build and support and just the horrible attitude of the company I say STAY AWAY!
weak CPU would affect DLNA playback too i guess but i am able to play 24/96 files stored on a media server without any issues. Perhaps its something else.
Dear friend,That’s what I was saying earlier, maybe the processer and memory resources near a tweak in a firmware upgrade, the stuttering and cutting songs at the end of one and start of another suggests some kind of memory management issue.
Seen this before with daps from both Fiio and Cayin
Dear friend,
Have you tried to update the Tidal in 2.11.4 for check? Because some users mentioned their issue with Tidal solved after the APP update.
Best regards
I approached this from the other angle. Got the Sony wh-1000xm3 for its noise cancelling and then looked for a small LDAC player, and got the M6. Sounds great and while the player is in my gym bag, I can choose Next Track or volume with the touch control gestures on the right side ear cup. Next objective is equalizing as the Sony is a bit bass heavy for me.
Hi @FiiO
I'm not sure if there is policy to reply to problems or bug fixes on these pages but perhaps you could advise if I'm wasting my time collating and sending message?
Some weeks ago I advised this:
"@FiiO
I have a question, is it just me or is the search on the fiio app broken?
I can't get my head around it... I type, say "Genesis" in the search box. It kindly shows me a couple of TRACKS with the word genesis in them, then the fact that there 132 tracks of the ARTIST genesis, and finally one ALBUM called genesis. If i click on the ARTIST icon (Imagining in some other logic based universe that it would go to the artist, genesis), it immediately starts playing the 132 genesis tracks. I can see all the tracks in a big "playlist" but it doesn't even mention which album they are from.
i.e. theres no flippin way to show the albums of the artist "genesis", via the search feature. What???
1stly, is this normal? 2ndly how do you work around it and why is it not clamoured for being changed in these pages?
BTW I've had the M6 for around 18hrs now. Lots to love. The form factor, screen and sound are great. Qobuz works OK too."
then subsequently this:
"@FiiO
please can I have a response to the above?
Also ref the folder view, why is the text truncated ? And why have the folder icon taking up valuable real estate? the width should be used in its entirety to MAXIMISE the folder text. Even the play buttons for each folder is superfluous; short press to open folder, long press to play, for example.
Also in album view, it would great to see the Artist also as a subset of the information
These "little" things would make the player so great!
Or simply whitelist some 3rd party players, like UAPP for example.
Neither of these 2 posts have received a response to acknowledge the issues.
Please can you advise further as my time is precious to me and I would not like to spend it further trying to elicit a response if there is to be none forthcoming. However, both of these issues are important, especially the non-functioning search feature which is extremely frustrating, as there are no other apps one can use as alternative.
Thanks in advance.
Dear friend,
Best regards
+1 on the casting app. Very much so.
Has Fiio ever replied to say it's not possible, or in the pipeline, etc?
