floeezy
- Jan 17, 2010
Hey, what is the material of the back of the M6? Aluminum or glass?
Thanks!
Thanks!
The back is finished in glass, and comes with a factory fitted screen protector.
hi,
Can you use the M6 as a bluetooth USB transport device? I'm looking for a bluetooth receiver with a digital out for my Chord Mojo.
If not, can anyone suggest a product that can serve this purpose? I want to be able to play music from my phone to the Mojo through bluetooth. And the Poly is ridiculously expensive.
Thanks.
Surja
Thanks for the information.Yeah, that should work. I haven't tried with the Mojo specifically, but you can definitely go from your phone over bluetooth to the M6 as a bluetooth receiver than USB-C out to a DAC in general.
Can you please confirm if its bluetooth receiver supports LDAC in this arrangement?
hi,
Thanks.
Surja
Perfect. Thanks for the help!Just checked with my phone sending LDAC (sound quality preferred setting) to the M6 (which says it's receiving LDAC), and then outputing to a Hidizs Sonata HD dongle DAC from the USB-C port. I assume a Mojo would work in the same situation. Just a heads up though, I don't get any playback controls other than volume on the M6 with this set-up, I have to use my phone to play/pause or change tracks.
Exact same thing happened with meA while back I reported on here that my M6 had developed horizontal lines across the screen. They seemed to be getting worse and I presumed that at some point they would make the screen unusable.
However, I have now noticed that the lines are all gone!
When the lines first appeared, the player had been kept in my rucksack at work, and the cold weather may had affected it. I never used since we went into Covid lockdown, and the lines remained.Read about this a few times. Very strange indeed. Hope that my unit will not develop the same. Anyway, glad yours is alright now!
