JWolf
- May 3, 2005
Bummer. Have so many files converted and now will have to redo them just for this player
Why would you use ALAC when FLAC is just so much better?
1. Music has been organized through iTunes for years of collecting. ITunes doesn't rip my cds to flac.
2. I have some Flac and don't notice much difference between the two in sound quality and file sizes are about same.
If you have music in ALAC and need a good converter (save re-ripping), try dbpoweramp - https://www.dbpoweramp.com/
Uses multiple cores, converts practically anything, and can also rip securely (same as EAC). Would be able to convert your entire collection pretty quickly.
The full version is USD 39.00, but IMO worth paying for. I use it every week in some form or other - I just find it is a swiss army knife for most of my audio needs.
Hi JWolf,
How is FLAC better than ALAC? Can you explain? Better in terms of sound quality? All I know is both are lossless format. Thanx.
Hi JWolf,
Better in terms of compression and better in terms of support. There are apps for iPhones/iPads that will play FLAC. side benefit of FLAC is that you don't have t use the awful music app in iOS 9
Hi JWolf,
It's not "better" in terms of sound but in terms of convenience since iTunes is a PITA to work with unless you really love Apple and aren't going to use anything else.
I would really like see something like fiio x3 2nd with at least fiio m3 battery life.
