Electrocrytic
Hiby replace them and the problem goes away
oh thanks. i've contacted my local agent and they immediately reached out to me. they'll replace the battery once the spare parts are ready.Dear friend,
Sorry about that. Please try to contact your local seller about that. If the seller fails to help, please contact support@fiio.com with the receipt attached.
Best regards
thanks for the very informative safety advice! i'm not using or getting my m17 charge so hopefully the situation wouldn't getting any worse. my local agent is nice and told me they expect to receive the spare part for replacement this weekend or early next week.@ddlo , that Li-ion bulging battery should be removed asap from the M17 - before the battery pops and ruins the M17, or burns your house down...
The swelling battery isn't safe to ship either! I hope your agent is close by, or find a local shop with experience removing a swelling Li-ion battery, like a PC Repair shop or other consumer electronics repair shop. If you don't know anyone, call your local fire department and explain the situation and ask them for recommendations where that battery can be safely removed and safely disposed.
I wouldn't leave your M17 with a swelling battery that has so much pressure it breached the fasteners of the case - as it is probably continuing to swell right now - sitting on or near anything flammable.
Lithium-ion battery swelling get worse over time, and the building pressure can pop the containment, or the swelling can cause the layers of the battery to split/open up and fail, causing the conductive elements to meet and short, resulting in a Lithium Ion Battery Explosion - like those Samsung Note 7 Lithium Ion batteries that swelled and exploded. Physically exposed LiPo batteries are more vulnerable to damage causing them to fail more often, and are just as explosive.
If you have a LiPo burn bag handy, or know someone that does - ordering and waiting for delivery of one might not be fast enough. Your M17 would be safer in a burn bag than sitting on a surface that will burn if that M17 battery blows.
The safest would be to put the M17 outdoors on a concrete block or slab , inside a Lipo Burn Bag, away from any buildings. The middle of the garage concrete slab would be 2nd best, but the outgassing and smoke from a fire would soon fill up the garage, and if you have an air vent connected to the garage from the house the smoke might be drawn into the house.
@FiiO would want the info off of the swelling battery - to track the manufacturing run the battery and that M17 came from - as others made in those batches might also be affected similarly. Where there is one, there are often more, especially since it was sealed into a closed unit that couldn't have been damaged by a puncture after manufacture.
Even though your local agent is solving your Lithium Battery Swelling replacement, @FiiO can benefit from the battery/M17 production batch info. The agent might pass it on, but then again they might not...
@FiiO - FiiO has been great at designing battery / power supplies and software/firmware that "do the right thing", and my M15/BTR5/BTR3k's all hold their full battery charge when off of the charger for a long long time.
I would expect all the batteries in the M17 would also hold their charges over time.
are there any news in terms of using the native qobuz app that bypasses the SRC - without coaxial output, so just using it as a DAP with battery mode and my meze empyrean?Qobuz bypasses SRC on the M17, at least through coaxial output
Yeah, it is hard to connect with the possibilities, that is why I was trying to provide enough information to help you realize the dangers, but it looks like you got from it that it only happens when charging, and well, it can happen when it is just "sitting there" all by itself without being connected to external power too.thanks for the very informative safety advice! i'm not using or getting my m17 charge so hopefully the situation wouldn't getting any worse. my local agent is nice and told me they expect to receive the spare part for replacement this weekend or early next week.
Btw, when you left it and didn't use it for a few weeks, what was the battery level? 100% or something else? I may just let mine drain from 100% andet it rest at aomething lower regardless.thanks for the very informative safety advice! i'm not using or getting my m17 charge so hopefully the situation wouldn't getting any worse. my local agent is nice and told me they expect to receive the spare part for replacement this weekend or early next week.
AFAIK it doesn't matter the level of the charge for a physical breakdown/incursion type failure, it can happen at any level of charge.Btw, when you left it and didn't use it for a few weeks, what was the battery level? 100% or something else? I may just let mine drain from 100% andet it rest at aomething lower regardless.
i played slightly <1hr before i went to bed the last time i used it (maybe last friday). i think it should be left with like 8x% battery. i didn't aware of the bulging when i last used it so i assume it happened sometime this week.Btw, when you left it and didn't use it for a few weeks, what was the battery level? 100% or something else? I may just let mine drain from 100% andet it rest at aomething lower regardless.
Phone explodes in man pocket
Samsung Phone explodes in Pocket
The process is chemical and although heat and power play a large part in initiating the problem, once started it can continue to "rise" and if a sharp edge / puncture or material failure occurs during the expansion which happens even after power is removed, you can still experience the catestrophic result.
The Samsung Note 7 battery failure due to the battery manufacturing problem caused it to be distributed world-wide so there are now a lot of "visuals" showing what can happen to Li-ion/LiPo batteries not under charge.
There were spontaneous battery failures while not on charge, and so I am including a summary article on those failures:
Samsung Issues New Warning for Galaxy Note 7s
Samsung Finally Explains the Galaxy Note 7 Exploding Battery Mess
Three months after Samsung killed production of the fire-starting Galaxy Note 7 smartphone, the company is now ready to explain what went wrong.
https://www.nbcnews.com/tech/tech-n...-galaxy-note-7-exploding-battery-mess-n710581
This video covers what the physical problem was that caused the failure, conforming the battery phisically to the phone internal structure, instead of designing the internals of the battery to the curve they "forced it", and caused the +/- plates to "touch".
Samsungs Verdict on the Note 7 - What REALLY went wrong?
@FiiO you had to conform the M17 batteries to internal cavaties, you didn't do similar "forced" method to make them fit did you?
My Note 10, S20 Ultra, and S22 Ultra have never had a battery swelling, nor have my dozens of Lipo and Li-ion batteries, but I do keep many in fire proof bags designed for Lipo batteries to contain the smoke and fire should they fail.
I hope your swelling battery and M17 have no further problem too... btw, does it feel "warm" to the touch?
Please let us know how it works out
On second thought I don't know the battery design or layout of the M17, so IDK if the M17 uses multi-cell battery design that can cause the individual cells to discharge at different rates and that in itself can be a cause for failure with LiPo cells. Again, not sure how @FiiO has designed the cells to interoperate in the M17.Btw, when you left it and didn't use it for a few weeks, what was the battery level? 100% or something else? I may just let mine drain from 100% andet it rest at aomething lower regardless.
fyi: the video is still online.So, M17 and external DAC’s issues… No issues here
I have been playing tracks all day and other than a little click on first initialisation (FiiO app only) It has been smooth sailing.
You guys either got two lemons (rare but, possible) or more likely, You guys are not doing it right.
Please be aware, I will restrict the video in 24 hours.
USB DAC mode is for using the M17 as a DAC, not an external DAC. In USB DAC mode, you'd use the 3.5mm or 6.3mm output to the TA-ZH1ES Line In.i wanted to buy the sony TA-ZH1ES. does anybody tried to use the usb dac mode towards the sony?
