Had the same issue with the demo version.Guys, do you also have issues with the M17 sliding out of the cover? When I take it in the hand if i don’t hold the cover against the M17, due to M17’s weight it slides out from the Cover easily. I will see if I can install a little magnet or Velcro.
[FiiO M17] Dual ES9038PRO, dual THXAAA-788+, dual power supplies, 9200mAh battery, 2 volume control modes
FM87DT
What do you mean by demo version?Had the same issue with the demo version.
cat3600
@JamesFiiO could you or someone at Fiio please answer my question on the USB volume level and if this can be disabled, thanks
sharexshare
- May 2, 2009
Thanks the information and sharinng about M17 , seems it's a great DAP
If i'm using IEM like campfire solaris or andromeda (rather sensitive IEM) , using medium gain , how the background hissing sound level compare with dap like cayin N6ii , AK sp2000 , Shanlinmg M8 etc.?
Thanks a lot
Thanks a lot
cat3600
I have both the M17 and M11 Plus and no hissing absolutely dead quite on balanced 4.4 connection, I have not used any other output except 4.4Thanks the information and sharinng about M17 , seems it's a great DAP
Thanks a lot
sharexshare
- May 2, 2009
Thanks a lot! I'm also using 4.4 /2.5 output mainly .
Could you share which earphone you are using ? Thanks again friend
My current Dap is shanling M8 , an I'm pleased as it's hissing sound level is very low , much lower than the cayin N6ii I previously used , but M8 battery life is bad , especially on streaming
cat3600
NP bud I have the Camfire Audio Andromeda and the Meze Rai Penta. I am used to a very black musical background as I have the Sony DMP-Z1 which is so quite and the M17 is very good indeed as well.Thanks a lot! I'm also using 4.4 /2.5 output mainly .
kel77
- Nov 16, 2015
You can change the orientation of the display on the M17 and the case flap will be on top?Ok i see… sad that the opening is not above the M17.
Loving my m17- currently using it with the Focal Utopia. The one bit missing for me is proper Roon support that circumvents Android's codec.
@FiiO any chance you can approach Roon about this?
Roon's app is one of the recommendations in the FiiO store app, I hope that this is a little hint that something is being done to address this.
sharexshare
- May 2, 2009
Thanks so much friend , got itNP bud I have the Camfire Audio Andromeda and the Meze Rai Penta. I am used to a very black musical background as I have the Sony DMP-Z1 which is so quite and the M17 is very good indeed as well.
FM87DT
I didn't even think about that...You can change the orientation of the display on the M17 and the case flap will be on top?
The only downside is that i can't lock the orientation display, it comes back in the initial position but that's no so a real issue.
I'll do that first before installing the second screen, thanks man
cat3600
Would be absolutely perfect to have Roon endpoint implemented and make it a perfect desktop replacement for a no of scenarios.Loving my m17- currently using it with the Focal Utopia. The one bit missing for me is proper Roon support that circumvents Android's codec.
does anyone get a temp to high alert when using it at low gain 50vol with iem?
behemothkat
It is around my usage scenario with MEST MK2 but I never had any temp alert even with All-to-DSD.does anyone get a temp to high alert when using it at low gain 50vol with iem?
cat3600
Never got a temp alert even with enhanced mode for 24 hours of straight burning in sessions. I do feel keeping it on the stand reduces the heat issue as it gets quite warm lying face down either side on the bed or tabledoes anyone get a temp to high alert when using it at low gain 50vol with iem?
Total: 14 (members: 0, guests: 14)
