I'll try to go, love the Duc !Thanks, I will check. Yes, Oriental Bass is the legend. By the way, a friend of ours (Tarek) will be playing in Paris in two days:
https://ducdeslombards.com/fr/l-agenda/tarek-yamani-afro-arabic-jazz-conceptions
[FiiO M17] Dual ES9038PRO, dual THXAAA-788+, dual power supplies, 9200mAh battery, 2 volume control modes
Choubdia
- Sep 19, 2016
Oh my deal Lafeuil i love le Duc des LombardsJe vais essayer d'y aller, j'adore le Duc !
Dear friend,Did the same mistake Can I also contact you to buy spare protection glass? Thanks in advance!
Sorry to hear about that. We have PM you about that. Please have a check.
Best regards
Dear friend,It would be good to have unequivocal clarification whether LO bypasses amp section from @FiiO
Yes, the lineout has bypassed the amp section.
Best regards
behemothkat
Sorry for reminding. How it does with Qualcomm?The sdk provided by Qualcomm is different, and we are communicating with Qualcomm about the improvement. Besides, the M17/M11 Plus LTD support Android 10 instead of Android 9.
Best regards
Sound Eq
- Nov 9, 2013
so strange not even one full review on m17 on youtube in english and comparing it to other totl daps
I was thinking of doing a review on YouTube but bottled out as I'm not at all confident with the sound of my own voice let alone my vocal review skills. My memory is somewhat 'shot' and I struggle to get my descriptive words out most of the time. If I was to write it all down I may as well write a bookso strange not even one full review on m17 on youtube in english and comparing it to other totl daps
I am into the process of reviewing the M17 but still on very early stages.
Looks like some kind soul answered your call....so strange not even one full review on m17 on youtube in english and comparing it to other totl daps
Sound Eq
- Nov 9, 2013
best review ever
FM87DT
Guys, do you also have issues with the M17 sliding out of the cover? When I take it in the hand if i don’t hold the cover against the M17, due to M17’s weight it slides out from the Cover easily. I will see if I can install a little magnet or Velcro.
Hi, all our cases are loose it seems to be. I believe though that it is so ventilation can circulate around the unit when placed on the Stand with Fan. I've found this most effective as the cool air is concentrated around the unit when within the case and keeps it cool.Guys, do you also have issues with the M17 sliding out of the cover? When I take it in the hand if i don’t hold the cover against the M17, due to M17’s weight it slides out from the Cover easily. I will see if I can install a little magnet or Velcro.
FM87DT
Ok i see… sad that the opening is not above the M17.
ScubaDrunk
Hi, all our cases are loose it seems to be. I believe though that it is so ventilation can circulate around the unit when placed on the Stand with Fan. I've found d this most effective as the cool air is concentrated around the unit when within the case and keeps it cool.
I found out by mistake that if you apply the spare screen protector to the DAP over the already factory fitted screen protector on the front screen, this will tighten up the fit but still leave enough space around the back for ventilation.
Before fitting the spare screen protector, my DAP would also feel a little too loose in the case and the bottom case flap would open up easily and the DAP would slide out if not careful.
After fitting the spare screen protector, this doesn't happen anymore.
FM87DT
Ok i see… sad that the opening is not above the M17.Hi, all our cases are loose it seems to be. I believe though that it is so ventilation can circulate around the unit when placed on the Stand with Fan. I've found d this most effective as the cool air is concentrated around the unit when within the case and keeps it cool.
Nice! Thanks for the adviceI found out by mistake that if you apply the spare screen protector to the DAP over the already factory fitted screen protector on the front screen, this will tighten up the fit but still leave enough space around the back for ventilation.
