FiiO M15 Audio Player | Dual AK4499EQ | 7490 mAh Battery | 64 GB ROM | $1299.99
Jun 12, 2021 at 11:11 AM Post #3,648 of 4,083
Never mind that my M15 can't run Apple Music. It still works so easily and well as USB DAC for Apple Music Lossless. 😆
Jun 12, 2021 at 11:22 AM Post #3,649 of 4,083
Runs Apple Music high res lossless too
Jun 12, 2021 at 1:13 PM Post #3,650 of 4,083
Jun 12, 2021 at 9:06 PM Post #3,651 of 4,083
Another fellow iPad M15 user
Indeed! And the interesting thing about the M15 is that when you select USB DAC, it works flawlessly. With the DX300 and the M8, it works intermittently. Not sure what I am doing wrong. For the AK SP2000, it’s intermittent too and even then, only sound comes out on one side…
Jun 17, 2021 at 8:47 PM Post #3,652 of 4,083
Jun 18, 2021 at 9:12 AM Post #3,653 of 4,083
Jun 18, 2021 at 12:43 PM Post #3,654 of 4,083
Apple Music will never work on M11, M11 Pro and M15. That's a fact.
Indeed. Tho it has a well implemented USB DAC function which I use to listen to Apple Music from my idevices
Jun 18, 2021 at 3:23 PM Post #3,655 of 4,083
What's so special about Apple Music that it won't work? Every other music app works fine. Why would it be different?
@FiiO
Jun 20, 2021 at 9:54 PM Post #3,657 of 4,083
@FiiO
Dear friend,
At present, the Apple music app can be installed in M15. But you could not sign in your account in Apple music app. This problem is a problem of the 7872 platform itself which need to be solved by Samsung.
Best regards
Jun 24, 2021 at 1:20 PM Post #3,658 of 4,083
fiio m15 is the only one dap that I know pays attention to the battery cable and the connector. The cable is custom FPC and the connector is from SMK.
I don't see ibasso, hiby, shanling, sony etc doing the same. at least they didn't mention
