Does the m15 have the different impulse response deals like A&K stuff has?
FiiO M15 Audio Player | Dual AK4499EQ | 7490 mAh Battery | 64 GB ROM | $1299.99
- Thread starter xenoVa
Dear friend,The only thing I still haven't figured out is whether with the output 3.5 both AK are used or not. If so, you could burnin even without using the balanced output. Thank you
P.S. with the FD5 it already sounds great.
Only one Ak4499 chip is used when using the 3.5mm headphone output.
Best regards
I wanted to point out three things that I noticed recently using the M15, the first is that although I have set the light to turn off on the volume knob and during charging this does not happen even if I turn it off when it is charging it continues to pulsate. The second is that in the FiiO music application both in android mode and in pure music the main language follows that of the system, while the one concerning the explanation of the commands is in Spanish I think ... even if I force it into Italian.
The third is that the display of the songs does not follow the alphabetical order, putting the songs starting with 1 at the end and thus mixing the execution order.
Sorry I said something wrong ... the error in the numbering does not happen between the songs but between the folders.
@FiiO or anyone els.
Its me or wifi 5ghz is bad on m15 ? Some times m15 cant connoct to my wifi 5ghz but its no problem on my old samsung S7 or nintendo switch.
And how do i turn of this notification ?
You have to disable the volume wheel in the lock on settings.@FiiO or anyone els.
Maybe rename, example CD02 instead of CD2. That may work.
5ghz works just fine on my routers.@FiiO or anyone els.
So no other way ? Like how i can lock volume wheel when he m15 is in my pocket but hate that popup
That's right, because if you have blocked the volume and the wheel turns in your pocket and you go to turn on the device it could also take your ears off, given its power and given the fact that you do not know the position of the wheel.
Ty for replyThat's right, because if you have blocked the volume and the wheel turns in your pocket and you go to turn on the device it could also take your ears off, given its power and given the fact that you do not know the position of the wheel.
gerelmx1986
I get the same issue in my WM1a and NW-A25 walkman
Haydn- symphonies CD 1
Haydn- Symphonies CD 10
And so continuee to disc 11 - 19
Then Haydn- SyMphoniew CD 2
haydn - Symphonies CD 20
Andso does 21 To 29 then jumps to CD 3 CD 30-33 and finalky diew the CD 4 to 9
same thing for roman nunerals vol. I to IV ok then makew IX before V to VIII
LightBlue77
Yes, because the sorting is text based, to put it simple, it doesn't know that the folder names are consecutive numbered based, hence whatever starts with 'CD 1' will always be sorted before whatever starts with 'CD 2'. The solution was already suggested, use names like 'CD 01', 'CD 02'.
Trying to connect my m15 to Cayin idac6 mk2 via usb. All I hear is noise in Fiio music, all other soft players provide only silence . What might be a problem? I tested this dac with windows, macOS, android. All works perfectly except fiio m15 player.
It may have to do with some apps not being able to work with DACs that have digital gain and hardware volume control.. I had the same experience with my Questyle DAC. The developer for UAPP made sure that when connected to my Questyle UAPP switched hardware volume to 100%. The FiiO music app does not have that possibility... But I never use the music app anywayTrying to connect my m15 to Cayin idac6 mk2 via usb. All I hear is noise in Fiio music, all other soft players provide only silence . What might be a problem? I tested this dac with windows, macOS, android. All works perfectly except fiio m15 player.
Total: 6 (members: 0, guests: 6)
