I think the only USB connector on the Cayin is the one to connect it to a PC as a DAC. Are you trying to use M15 as a digital source for the Cayin DAC? You can do that with the coaxial digital cable. But you would still need an extra headphone amplifier .Trying to connect my m15 to Cayin idac6 mk2 via usb. All I hear is noise in Fiio music, all other soft players provide only silence . What might be a problem? I tested this dac with windows, macOS, android. All works perfectly except fiio m15 player.
FiiO M15 Audio Player | Dual AK4499EQ | 7490 mAh Battery | 64 GB ROM | $1299.99
- Thread starter xenoVa
Nope.. Should work. But as I said earlier, use UAPP and put hardware volume to 10 (100%). I have my M15 connected to. Questyle DAC/AMP via USB out.. And without maximum hardware volume in UAPP it will keep producing hissing... As the UAPP dev explained, this happens with devices that have both digital gain and physical volume control
LightBlue77
why are you using M15 like this? any average smartphone would be faster and more reliable than M15.
Because I want my music in 1 place. My M15 carries a 1tb SanDisk with my library and drives my headphones in balanced mode when I am not in my listening room. In my listening room I connect it to my Headphone Amplifier. My M15 therefore is the central source component whichever way I deicide to listen... Even with Bluetooth headphones or in my car I use the M15 as source.why are you using M15 like this? any average smartphone would be faster and more reliable than M15.
jeanolivier
Hello everyoneC Cannot pair a B&W P17 in APTX HD.
Only in APTX.
I haven't had a problem with my PX7. Anyone have an idea?
Many Thanks .
Only in APTX.
Many Thanks .
Dear friend,Hello everyoneC Cannot pair a B&W P17 in APTX HD.
Only in APTX.
Many Thanks .
Please check whether you have switched the output wireless playback quality in the player to APTX HD and connect again?
Best regards
jeanolivier
Thank you. It's already done. When I set it to APTX it connects. If I set it to APTX HD after restarting bluetooth, it no longer connects. Or rather it connects but M15 tells me "'connected without reading media".
I don't think the problem is with the M15 and wanted to know if anyone had tried with a P17
In the end we always say that it is the fault of the M15 even when it is not to blame...
jeanolivier
Hi! I just made my purchase of a Fiio M15. I was an early adopter of mp3 players back in late 1999 or early 2000. I can still remember my precious 16mb CF card player of some type. I've always wanted a high-end one for more modern uses and it just so happens I really need a good headphone amp and DAC for pro audio use...so happy to join the Fiio family I've heard so much about.
Now, I await shipping...
Excellent choice, definitely the last dap with 2 ak4499 on board.
It seems that a firmware upgrade is coming soon, bringing some features from the M11 Plus as the view meter. Any release date Fiio?
Got my M15 last week and I've been really enjoying it since (with my AKG K240 and K702 headphones).
Grabbed the correct case on Amazon and love the design and better feel of the buttons in the case.
Only negative so far, which isn't really FiiO's fault, is that the M15 doesn't work with my car's USB port. I have to use the Bluetooth which then messes with my phone connection. Oh well, better than nothing. Next I have to figure out some of the more advanced features like the wifi server/client setup.
Where do you see a firmware upgrade coming?It seems that a firmware upgrade is coming soon, bringing some features from the M11 Plus as the view meter. Any release date Fiio?
