FiiO M11Pro | Dual AK4497 | THX AAA 78 Headpone Amp | 5.15" 18:9 720P | Exynos 7872 | 3G Ram+64G Rom |
Mar 14, 2020 at 5:38 AM Post #1,082 of 1,931
To FiiO:
Since we have managed today to get HiRes mode and DSD mode working with USB Audio Player PRO (UAPP) on the FiiO M11 PRO, people are asking why they cannot download our app from the Play Store on the FiiO M using your recent update. The problem is that USB Audio Player PRO requires USB host mode to be active on the Android device, otherwise the Play Store will say it is incompatible. Now since the FiiO M11 support USB host mode, there is a misconfiguration. Can you please solve this?
The details are somehow like described on this page:
https://github.com/452/USBHIDTerminal/wiki/How-to-enable-USB-host-API-support
Basically it's just adding a host XML file. Since it requires root permission, users cannot do this themselves.
Hi, we have already solved it and release a beta version now >>>Click here
Mar 14, 2020 at 10:57 AM Post #1,084 of 1,931
Hello,
The 2.5 and 4.4 balanced ports of the M11 are parallel, so theoretically there is no difference in sound. Do you have another 4.4mm headphone for check? If the issue still remains, it may be a hardware issue with the 4.4mm port.
Best regards
Solved. Cable issue. Cable returned to manufacturer :relaxed:
Mar 20, 2020 at 8:59 PM Post #1,088 of 1,931
Is it me or the EQ in fiio app isn't working? Using the normal firmware, not the beta
Mar 21, 2020 at 5:35 AM Post #1,089 of 1,931
Hello,
Did you turn on the MQA option? What's the firmware version and app version of your M11PRO?
Best regards
Mar 21, 2020 at 5:46 AM Post #1,090 of 1,931
Hello,
Best regards
MQA is ON. I turned it OFF and it stays the same. I'm on Firmware 1.0.1 and app version 1.1.7.
While I'm on this i'm also aware that on searching album art, on certain situation where artist or album is left empty on the metadata, it will not search anything at all. What I'm suggesting maybe also increase the search based on filename too? Probably some songs like WAV file whereby there is no metadata while Flac does?
Thanks for the swift response by the way and it's weekend. 加油还有注意健康卫生!
Mar 23, 2020 at 3:30 AM Post #1,091 of 1,931
Hello,
Please try to update the app to V1.1.8 and check again: Click here
How to update the FiiO Music app
a. Set the player to storage mode and connect to computer, drag the downloaded FiiO Music (.apk) to the internal storage of your player.
b. Disconnect the connection and enter ES file manager, find the FiiO Music app in internal_sd and click install.
We will report your feedback to the engineer and check the feasibility.
Best regards
Mar 28, 2020 at 3:43 AM Post #1,093 of 1,931
Dear FiiO
I just updated M11 Pro to the latest firmware 1.0.2.
I can confirm the noise issue with AllToDSD and Tidal is now fixed and working properly :)
Thank you for this fix!
Hello,
Glad to hear about that. Thanks for the feedback.
Best regards
Mar 29, 2020 at 7:52 AM Post #1,095 of 1,931
Sure it's quiet over here. Seems like M11 Pro user are much satisfied with their player
