A firmware patch to enable Google Play store in M11/M11PRO/M15 based on the SoC used--Samsung 7872
Download link:
http://fiio-file.fiio.net/Google_Play_Update.zip
How to update: Copy the firmware package file to the internal memory or micro SD card; Open "Technical Support" app on the M11/M11PRO/M15->enter the "Firmware Update" menu->select the firmware package file to upgrade.
Note: The Google Play partial library will prompt for updates after connecting to the Wifi for the first time. Restart it so that you could use it normally.
What can be done if receiving 'the device is not certified' in Google Play?
Currently, Google has closed the channel of GMS certification for Android 7.0 devices. So you will be prompted that the device is not certified. You can register your device by following the steps below:
(The deivce without certification could use Google Play normally still, but some apps with high security requirements could not be searched. )
1. Install the DeviceID.apk
2. Click it to get the 'Google Service Framework' and then copy it
3. Go to the following website and fill in the ID copied from step 2
https://www.google.com/android/uncertified/
If you have any questions or advices,please post in this thread or send an email to
support@fiio.com
Best regards
