Moreover, I think this problem applies not only to the Fiio music app, but also to the system in general, I noticed this on streaming. Anyone else?Still hasn't fixed the issue I and others have reported of the app cutting off the first note of some songs.
[FiiO M11 Plus LTD/M11 Plus] THXAAA-78,Android 10, 2.5/3.5/4.4 Powerful Output/4.4 LO output, Dual AK4497/ES9068AS DAC chips, 4GB RAM,64G Flash
- Thread starter FiiO
Shemp Shempington
It has to be the unit itself as the FiiO app works just fine on my phone.Moreover, I think this problem applies not only to the Fiio music app, but also to the system in general, I noticed this on streaming. Anyone else?
Mr.Toad
- Apr 25, 2002
I’m having a problem with Tidal MQA files on the M11 Plus. For the first 5-10 minutes of playing an MQA track I get stuttering audio. This happens with both streaming and downloaded files.
After the 5-10 minutes, the stuttering clears up. UAPP has the same problem, so it’s not the Tidal app.
Neither Tidal nor Fiio support were much – any, actually – help. Their response was “cannot reproduce”.
I’ve tried: app reinstall, factory reset and reverting to older firmware without any success.
Any suggestions? Anyone else have the same problem?
Dear friend,I’m having a problem with Tidal MQA files on the M11 Plus. For the first 5-10 minutes of playing an MQA track I get stuttering audio. This happens with both streaming and downloaded files.
Yes, sorry we did not reproduce the same issue in the M11 Plus. You may try the Tidal app in other version to check again? I tried 2.48.0 version with loudness normalization off in Tidal app.
Best regards
Mr.Toad
- Apr 25, 2002
I did try a number of different versions of the Tidal app, including the old version on the Fiio app store. and all had the same problem. Besides UAPP does exactly the same thing, so it isn't app specific.
Yes, this track is 8x unfolded in my R7.It will depend on the tracks you are listening to - very few unfold eight times. Most unfold 2x to 88. Search up Jan Gunnar Hoff 'Polarity- an Acoustic Jazz Project'. That plays unfolded to 385 or whatever for me on the M11 +.
Maximiliano Campo
Hey all, I have a question about EQ on the FiiO M11 Plus ESS, I can use EQ fine on the music player mode, but when I try to EQ songs playing on Tidal, I can’t find any EQ option.
Maybe there’s something I’m not doing.
How can you EQ songs playing from Tidal on this DAP?
I’m so stuck and can’t find answers anywhere.
Thank you in advance.
buckster666
Got my dispatch email from OTIC-audio, should hopefully get it tomorrow
rlw6534
Both Wavelet and Poweramp Equalizer work with Tidal on the M11 Plus ESS. Just note that full MQA rendering cannot be performed when EQ is being used.
received the M11 plus ESS today, i previously owned the M11 a few years ago but sold it when apple decided to move over to lossless and the M11 could not install apple music. I ended up just buying an apple dongle and playing music off my iphone. M11 plus now updated to Android 10 and apple music works flawlessly. I love listening on high gain mode
buckster666
Welcome to the club.received the M11 plus ESS today, i previously owned the M11 a few years ago but sold it when apple decided to move over to lossless and the M11 could not install apple music. I ended up just buying an apple dongle and playing music off my iphone. M11 plus now updated to Android 10 and apple music works flawlessly. I love listening on high gain mode
thank you very much sir
Inserthouse
I don’t have options for Tidal or other High definition streaming apps(Not available in Japan) so I am forced to use Apple Music and it works very well.received the M11 plus ESS today, i previously owned the M11 a few years ago but sold it when apple decided to move over to lossless and the M11 could not install apple music. I ended up just buying an apple dongle and playing music off my iphone. M11 plus now updated to Android 10 and apple music works flawlessly. I love listening on high gain mode
Off topicI don’t have options for Tidal or other High definition streaming apps(Not available in Japan) so I am forced to use Apple Music and it works very well.
I got interested in your statement.
It's true that you can't buy a Tidal subscription in Japan - it's very strange.
But in general, Tidal service/streaming is not blocked if you already have or bought such an account outside of Japan, or e.g. you came to Japan with an already working Tidal.
I once read that in Japan there are streaming services even in better quality than Tidal, for which you need a very fast internet.
Do you know anything about you used them on your FIIO M11?
using 2.5mm balanced cable with my simgot EA500 and Yanyin Canon, currently on 50-55 volume on high gain - do you think i can achieve 9-10 hours battery life?
Total: 8 (members: 0, guests: 8)
