I saw people using this one on some forums:Hi. My Fiio M11 plus ltd battery is swollen. Where can I find replacement??
https://aliexpress.com/item/1005004981557643.html
it has higher capacity and excellent reviews.
Dont charge good the link can you add some photo of aliexpress productI saw people using this one on some forums:
Thanks. Very bad with fiio. To repair I have to send it to China or look for a battery on "ali or ebay". This is what Fiio told me, incredible. Fiio is dead for me. It was my last fiio, a battery on 18 months. All my fiios are on sale.
Dear friend,Thanks. Very bad with fiio. To repair I have to send it to China or look for a battery on "ali or ebay". This is what Fiio told me, incredible. Fiio is dead for me. It was my last fiio, a battery on 18 months. All my fiios are on sale.
For some reason, your competitors, during the warranty period, calmly assumed the cost of shipping and after they made sure that the device, which was really unusable, sent a NEW one.Since the custom in China is too strict, it is too difficult for us to send a pure battery to oversea country.
Thanks god i've sold mine in advanceHi. My Fiio M11 plus ltd battery is swollen. Where can I find replacement??
Dear friend,For some reason, your competitors, during the warranty period, calmly assumed the cost of shipping and after they made sure that the device, which was really unusable, sent a NEW one.
FOR FREE.
I already wrote that if they made portable players, then I would never look in the direction of fiio.
Is it hard for you to do the same???
Due to the specifics of our country, I buy all the goods that interest me on the Internet. Chinese - on Ali.If you bought our product from the local authorized sellers
Dear friend,Hello,
at the moment I use my iPhone 13 together with the FiiO BTR7 to listen to Lossless or Hi-Res Lossless Songs via Apple Music. Headphone is the Focal Clear MG (via balanced cable 4.4). So, I'am looking for a DAP that has the following features:
I want to use Apple Music with the M11 Plus. Can I use it in the same way like on my iPhone 13, for example can I download my Apple Music playlists with hi-res songs to the ZX707 in order to hear them when I have no wifi connection?
How does the equalizer of the M11 Plus looks like? Has it the same functions like the Equalizer of the BTR7? I normally use the Oratory settings for my Focal Clear MG, is this possible with M11 Plus EQ? And when doing these individual equalizer settings, do these affect to Apple Music?
Lots of questions, thank you for your support.
Dear friend,I am thinking about using an external headphone amplifier for FIIO M11 Ltd.
When I use balanced LO, it can be considered that I skip the entire internal amplifier path, the signal is directly from the DAC?
Then why does the message appear that using the balanced LO output the volume is set to max. - (max from DAC or max signal from the internal amplifier)?
When using balanced LO - setting the gain LOW, MEDIUM, HIGH - does it affect the quality of the signal?
Hello Dear FIIODear friend,
1. If you did not enable the 'line out volume adjustable' option, the 'volume is set to max' message will show when switching to line out mode.
2. In volume adjustable mode, the gain will affect the output volume.
Best regards
