BadReligionPunk
YEA, and it will cost double the M11 too.OT. So the specs for Cayin N6ii are out.
It is easy to believe that ”bigger is better” but apart from price and power requirements is is also important to recognise that memory gets cheaper with time.Just out of curiosity, can anyone clarify what prevents consideration of larger internal memory.
Is it generally a cost consideration or are there technical limitations?
Is this the new one where the whole motherboard (DAC and amp) are replaceable?OT. So the specs for Cayin N6ii are out.
Yes it is. I am also thinking the price is at least double that of the M11.Is this the new one where the whole motherboard (DAC and amp) are replaceable?
Thanks for the insight.Hi dude
My thoughts on these three are the following : M11 is the best of both. While X5 III has a really good and detailled sound, the strenghts for the R6 was on smooth android experience and a fun, warmer sound. So M11 got a well balanced and quality sound, with a touch of warm on low-mids and a really good lows/bass handling. That being said, the overall sound definition/quality jump on M11 keeps tight as both R6 and X5 was already really good units.
How did you get that discount?I pre-ordered an M11 yesterday from advancedmp3players - real bargain working out £363 including topcashback. I currently have an AK70 mk2, but it is starting to feel dated software wise with no firmware support, offline Tidal and only aptX HD bluetooth . I do like however its build quality and sound, althought I am increasingly using it just as a transport with a Hugo2. I am concerned whether the M11 will feel a downgrade to this in terms of finish and sound - does anyone here have an opinion?
For me, yes. There is no compromize on the unit. I definitly got my reference mid range DAP here, best experience so far.Thanks for the insight.
So, If I understand correctly, you rate M11 higher than X5iii and R6? That's quite an achievement if that's the case.
Sounds greatFor me, yes. There is no compromize on the unit. I definitly got my reference mid range DAP here, best experience so far.
How does the Z7M2 pair up with the M11? I don't have an M11 but I'm considering getting a pair for my ZX300. Read your signature and thought I'd ask.For me, yes. There is no compromize on the unit. I definitly got my reference mid range DAP here, best experience so far.
It was 15% for Easter weekend and 6.4% on TopCashback - Quidco is only 3.2%How did you get that discount?
I'm only able to see 10% discount for over 250 purchases and a 3.2% cashback rate.
I see. I would probably got that deal too if it was still available.It was 15% for Easter weekend and 6.4% on TopCashback - Quidco is only 3.2%
any word on when the M11 will be available in the german FiiO Shop?
We had decided not to remove the TF2 from M11, but for the future model we will remove the TF2 and may add the build in memory size to 64g or 128g.
Yes. I agree about Quidco, but I always check TopCashback just in case.I see. I would probably got that deal too if it was still available.
You're right. Quidco is 3.2. I'm using Quidco mainly as from experience I find Topcashback is unreliable.
