jmills8
Previously known as bmiamihk, jmills2
By gym you mean , sitting and watching others work out ?M11 is my gym dap![]()
If I do go to a gym then I would use my old X3 dap with an Arrow amp.We cant all action DAP like you and the hugo 2![]()
In many postings I described the gaps....
I'm using BT LDAC and for this connect I get micro gaps / glitches from time to time in a track - it's not track specified. It's a device HW / OS / FW issue.
At M7 & M9 in near every track I can hear this kind of gaps (a break of a millisecond (or less) in a track, not track specified - cause I cannot reproduce that behaviour with the same track, it's ocurring from time to time).
At M11 it's a little bit better, but the gaps are still existing (FiiO music app). I tested my preferred music app (I use this app for 5 years) and I know this app is perfect in music playing (gapless playback etc. pp.) but I can hear the gaps in limited amount. Its' okay but not perfect...
A few days ago I installed Neutron for testing.... and it seems, Neutron can handle the BT LDAC connect better than all the other apps (incl. FiiO's). This is funny and sad for FiiO.... but I hope the gaps are gone....
You can hear the gaps in a hard-hitting beat. The gap produces a break in the beat by a millisecond and the beat is "out of control"...
Poweramp vs. Winamp = I know.
P.S. The tracks are normal ripped and encoded FLAC files 16 Bit 44,1 KHz files compr. 6 ~900 KBit....and normal encoded MP3 files....
P.S.S. micro gaps <> gapless playback
I am using WH-1000XM3 in LDAC Quality mode and does not noticed any gaps between all kind of track. Maybe you should think about formating your sd card, or factory resetting your player.
One thing which I was noticed that for some reason in many track I've got a distortions on a fade out of a tracks.
do you drop the soap like you do your daps![]()
Good one and I leave stinking cause I might drop the soap.do you drop the soap like you do your daps![]()
Hi,
What coaxial cable do I need to connect the fiio M11 to my Hugo 2?
I need it to be short for stacking.
Maybe try here https://www.audiosanctuary.co.uk/custom-cable-cc35-3.5mm-coaxial-cable.html sorry if I'm wrong
4 mate here is a pic of the cable that comes with M11
