Jujoe
What app are you using? And does it port in purchased albums from the likes of Amazon music and quboz. That's one thing I like about the fiio app
Its the Hiby app
Hope this helps
Juj
Hello, I was listening to neutron evaluation and although kind of ugly it sounds better than fiio and hiby players. Where do I buy it from?
https://neutronmp.com/buy.html
Mine looks pretty sweet now, I can share config files and theme files for the best sound from this awesome app. Mines fixed to output everything at 384khz 32bit with 64bit dsp and dither
Can I purchase on my comp and transfer to player or do I need to download straight to M11?
You need to purchase the paypro version. You can do on your pc or phone etc. The license is tied to your email address. But you need to setup an email account on your m11, see here:
http://neutronmp.com/forum_nmp/viewtopic.php?t=5447
I do have a better way if your struggling. PM me after purchasing it.
So I got my Oriolus BA300S... well my second one. First thing the one that Penon Audio sells isn't the japanese one. It's chinese made, and the one I got wasn't working properly. Left side had almost nothing come out of it. Returned and picked up the JP version.
First Impression... BASS!!! Lots of it. It makes me question if i'm a true basshead when i'm getting so much bass. I didn't get this impression from the chinese made BA300S.
Using FH7, LC4.4D cable, M11, BA300S JP
I wanna give it time to burn in before giving anymore impression.
Hey mate, this apps awesome! One question, how do I update this thing on m11.?
No auto update but you can check the details tab opposite the ARM64 versionn every so often. If a new one comes out just download and install over the top.
http://neutronmp.com/downloads/category/1-generic-android.html
Still not so sure about the warmth but it is taking that artificial/digital edge off of the music coming from the M11. My first impression was "LOL, What!?!" that was from the impact of the bass and just the sheer amount of it.I'm eyeing the little bear tube amp thanks to hbb I thought they were all made in China just the Japanese one had the cables?
I don't have a problem with bass on the m11, but with planars coming I'm going to need more warmth I think.
Thanks, I got the NEON version, well that's the one that was in the link.
