Jujoe
Has anyone else had the music stoping and starting when looking through the fiio app and using 3.5mm in line out mode??
This is only started today.
Juj
Juj
... but it's possible for smartpone and tablet manufact....sorry, it is too difficult to us to make so many different accessories for our products.
Yoda says: You must use another kind of connection, young Padawan.Has anyone else had the music stoping and starting when looking through the fiio app and using 3.5mm in line out mode??
Juj
It sucks that they can't provide a flip case, but at least they offer a screen protector so I'd just resort to using that for protecting the front side... but it's possible for smartpone and tablet manufact....
Why not for you? The silicone and the leather case do not protect the whole M11 device.... the display of my M9 makes problems after fall to earth! A better protection would be helpful! The M11 is too large and too heavy without any protection - and sorry the leather case does not protect the display! In addion why don't you offer a belt clip case for your products? Why are you offer many HiRes Player without any reason (maybe all HiRes formats are "funny" formats!) but without a good case support? I use a camera case! This is sad....
Does the issue occur with other apps or just FiiO's?Has anyone else had the music stoping and starting when looking through the fiio app and using 3.5mm in line out mode??
Juj
Juj
Ok, I apologize if this has been asked as I did a search and nothing came up....
Now how in the hell do I install the Micro SD cards??!! I have a needle and am pushing it in the little hole to eject the tray but nothing is popping out? Am I not pushing hard enough? Sounds ridiculous but I dont want to force and break something an hour after I got it!! Thanks!
Better to use the tool that came with the m11, it's a little wider and sturdier and not sharp it's the metal thing in the box.
Of course its on the backside of the cardboard!! If you didnt post that I would have never known it was there!!! Thanks very much!!
Cheers!!
