FiiO M11-Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Discussion in 'Portable Source Gear' started by FiiO, Mar 19, 2019.
Tags:
201 202 203 204 205 206 207 208 209 210
212 213 214 215 216 217 218 219 220 221
  1. fatmanny
    I'm using aptX-HD. I'm going to try the other connections right away.
    Edit: Same issue across all types of wireless quality. No matter if I use the wheel or the slide bar on screen, it's like the volume gets turned down at the same rate I turn the volume up before it turns up to where it should be.
  2. zeroselect
    Too fitted for that. You have to pick one or the other.
  3. Jujoe
    STRRRRRRREEEEEEEEETTTTCH it lol (joke) Thanks for the swift get back.
    Juj
  4. abitdeef
    That's most puzzling, maybe ask fiio about it? I would say it's your headphones but if it does it on all your sources. I checked it on my Sony bt speaker and it was normal also.
  5. abitdeef
  6. fatmanny
    I'm using the RHA MA750 wireless, which support Qualcomm aptX. I never had this issue with my S8+.
    @FiiO I'm having the volume drop momentarily when I raise the volume on the device while playing through bluetooth on multiple devices.
  7. gmahler2u
    My unit is coming tonight. Hooray!!!
    Out for delivery..
    Ryokan and abitdeef like this.
  8. JRichardson1228
    From what I can gather from the Headfonics review, under the Accessories & Packaging section, it looks like the amp actually comes with three 4.4 -> 4.4 connectors. The only difference is the JP version looks to be of a nicer quality. So I guess that solves that problem, though it would have been nice if all versions came with the connector in the JP version,
  9. Jujoe
    Thanks for the info.
    Juj
  10. harpo1
  11. exitfire401
    Not having any issue on mine with rc-bt and FA1 over aptx. Really odd
  12. Jujoe
    @FiiO I have installed sonarworks via APKPure on my M11 but unfortunately the play/pause and track forward and back buttons on the side are unresponsive when playing back in the app.
    Juj
  13. Starlights
    hello,
    recently i've just received this m11. its a beautifull dap to me.
    and want ask a question : did someone know how the power led lights on ?
    is it when it played a sond or just turn on the device ? mine did not lights on neither.
    (sorry for my bad english). please need some advice.
    thanks
