Ok, got it a little while ago. I'll post more detailed impressions in the days to come but here is my first report (single ended to InEars Prophile 8s, comparing to X5iii):
Beautiful unit - really quite lovely.
Fast and smooth - within Fiio's music app it's whizzing around, no discernible lag at all. Especially navigating folders, very quick. Also going from app to app and opening apps.
Sound - hard to say at this point. For one thing, I am accustomed to listening through the XD-05 and thus will have to AB between M11 and X5iii to give meaningful feedback. Best I can say at this point is the M11 is much more refined. There's more detail but not just in high frequency. Like an overall higher resolution, if that makes sense.
Is the soundstage wider? Again, hard to say without ABing and also running through the XD05 to properly compare.
I would say it represents a similar experience to when I tried out the Opus #2 in that it's clearly better (than X5iii) but I couldn't tell you more right now.
Bass - not subdued but not powerful either - EDIT: I was wrong. Bass is as it should be, punches well if it's in the recording, and reaches down nice and deep.
EQ - works very well (within the Fiio app) and does not seem to make the 6db drop that previous versions have done. Definitely an option to those wanting more bass (tried it, sounds good)
@gLer and @Sven2015 had a bunch of questions - I'll answer them here so everyone benefits:
English language - yes, plus a ton of others.
Bluetooth and 5g Wireless - yes, no problem. Bluetooth LDAC to the Mobius sounds good.
Boot-time - minimal. Haven't timed it but we're maybe talking 10 seconds, if that. Quick!
Gapless - haven't tried yet, will be walking the dog after this so will try
Plex - not till tomorrow BUT
When I tried YouKu to test wireless, video and audio I discovered there is no orientation option. The player will not detect when you turn it on its side and there is no setting to enable this. This may mean no landscape video, though some players allow you to set this within the app. We'll see. But this is not a player for YouTube etc...
Overall, at this early stage: am I happy with it? Yes, very much so. Flawless operational experience compared to the X5iii and arguably improved sound quality, plus LDAC, improved battery life. Very happy with this upgrade. Is it a redefinition of sound in the same way my Prophile 8s were? No. But I believe it rivals the Opus #2 which is more than double the price (only my opinion based on memory, pinches of salt recommended) and to really step up in terms of sound I would need to move to a much larger budget and even then, I suspect it would not be a night and day difference (to my ears at least).
Great job @FiiO ! This is a lovely player, a worthy upgrade to the X5 series!!
Feel free to ask me to try things out - I'll keep reporting back as and when.
