FiiO K7/K7BT Desktop DAC&Headphone AMP Discussion | XLR Balance | Dual THX AAA | Xmos | ...
May 25, 2023 at 6:28 PM Post #1,097 of 1,566
USB pin connect:
  • Pin 1 (Red): +5V.
  • Pin 2 (White): Data –
  • Pin 3 (Green): Data +
  • Pin 4 (Black): GND.
May 26, 2023 at 10:11 AM Post #1,099 of 1,566
Yeah, I doubt it was the cable so much as it was the process of unplugging it and plugging it back in. Some software or firmware malfunction that got reset by reconnecting.
May 26, 2023 at 7:24 PM Post #1,100 of 1,566
I agree. It is most likely what you said.
@FiiO I've just ordered a non-bluetooth K7 from one Aliexpress seller. Is it possible to know if I will receive the updated version ?
May 26, 2023 at 10:24 PM Post #1,103 of 1,566
Dear friend,
IF bought from FiiO’s official AliExpress store, Yes new version. If you bought from unofficial 3rd-party AliExpress stores, we could only check if you could provide the SN code to us.
Best regards
May 26, 2023 at 10:40 PM Post #1,104 of 1,566
IF bought from FiiO’s official AliExpress store, perhaps. Who knows with unofficial 3rd-party AliExpress stores - it depends on how old their stock is…
Dear friend,
Best regards
Is there an echo in here? 😁
May 29, 2023 at 3:31 AM Post #1,108 of 1,566
Hi @FiiO I just got my K7 and am worried about the build quality of the connectors at the back. The USB-B port seems to have some flexible movement (up/down)- am afraid this doesn't indicate a long life of plugging in and plugging out on this port. Do you have any words of help on this?
